Page 65 of 69 FirstFirst ... 15555657585960616263646566676869 LastLast
Results 641 to 650 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #641
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Quote Originally Posted by theonlykid View Post
    It is 1 of 2 things and neither one is a corrupt BIOS.
    #1 you don't have the P4 connected to the board to provide power to the CPU
    #2 If you are using the P4 you have a bad board. We have gone through a ton of these boards with a relatively low failure rate. However the top failure is exactly what you are describing. I have no idea what the weak point on the board, but there is something in the design that when it fails the video goes out but the green light comes on and fans still spin.
    I agree regarding the P4 connection. Make sure that you have it connected..silly but simple.
    "Live Free!!!...It's all about Open Source"
    Current Proj:Android Mount in 2013 Altima
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #642
    Constant Bitrate txspazz's Avatar
    Feb 2008
    TEXAS
    Yes, P4 was connected. It went from running - shut down - attempted restart and no more working. Tried different PSU, pulling memory. I let it sit with the battery out and disconnected from the power supply for a week as that had worked once in the past, but no dice this time. Intel didn't give me any flack over it. I talked to 'em once and they said try resetting the BIOS and if that didn't work get back with them and they would get me a new one.
  3. #643
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    My issue is solved with the dual monitors now. It was the vga splitter I was using, I'm assuming that it was having power fluctuations as it was powered via the car's 12 volt. I'm going to try to macgyver a connection to the OPUS over the winter (thankfully no shows until April at the earliest).
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  4. #644
    Variable Bitrate Deric's Avatar
    Sep 2006
    I had the same problem as you. One day booted just fine and then the next nothing but green light and fans without POST. I had to RMA my board. I also had issues with the board booting with my Opus. I had to manually power on the board to get it to work. After my RMA all was good.
    Quote Originally Posted by ctec View Post
    Hey guys. I have a problem with my board. when i turn it on the fan spins and keeps spining and the green light on the motherboard light up butt nothing comes on the display. After searching on internet i found out that maybe the bios is corrupted due to some reasons. I followed the steps to recover corrupted bios with a usb and a .bio file without any success.
    I want to ask you guys if someone can help me.
    Nov 2009
    Someone from the store where i usually buy this stuff told me that the bios can be damaged due to tempratue and humidity. What do you guys say about that.
    What are the temp range for this mobo ?
    Is it possible that in winter ( As the guy said ) it will be a problem to use it ?
    I bought a new one, D945GCLF2D.
  6. #646
    Sep 2009
    Cow Creek, CA
    I have a D945GCLF2D and am having the very same issues described, green light comes on, fan spins and no video. However, this happened to me my very first boot (see thread here), could I be having the same issue? I don't currently have a P4 cable, but I'll order one tonight and test that before I RMA.
  7. #647
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Dezdan, the mobo WILL NOT POST if the P4 connector isn't connected.
    Tidder
    Try RevFE
  8. #648
    Sep 2009
    Cow Creek, CA
    Quote Originally Posted by Tidder View Post
    Thanks, P4 on order.
  9. #649
    Constant Bitrate vull's Avatar
    Oct 2007
    Quote Originally Posted by BigIg View Post
    It actually underclocks ram to DDR2-533.
    I've played with this board and performance is more than good enough for CarPC environments.
    only D945GCLF2 will support 667MHz ram then?
    no option for D945GCLF2D in bios to use higher speed ram?
    taken from here:
    http://www.mp3car.com/vbulletin/revi...ml#post1352074 (stupid large pics need to load)
  10. #650
    Sep 2003
    New Mexico, USA
    As far as I know vull, D945GCLF2 and 2D both underclock the ram to 533mhz. I noticed that my old D945GCLF board shows in the BIOS setup the ability to set 667mhz as the ram speed, but did not find this option in the GCLF2 or 2D. I think I'll pull the ram out of my D945GCLF system just to test, maybe the 667mhz option shows up with supported ram only? I find it hard to believe that the GCLF will support and run at 667mhz and the 2/D will only support it at 533.
    EDIT: After playing around with this on my D945GCLF, setting the ram to 667mhz causes the system not to POST. Perhaps this is why they pulled support for it in later atom-based boards? I'm not sure, I need to look up the timings for this ram to make sure I'm not setting something incorrectly. Thus far though, I'm thinking it just wasn't meant to be.
    EDIT2: It appears that the bios is the same for the D945GCLF and GCLF2/2D. I will compare BIOS versions and see what I find.
    Tidder
    Try RevFE
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 08:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
