Page 68 of 69 FirstFirst ... 18585960616263646566676869 LastLast
Results 671 to 680 of 688
Thread: Intel D945GCLF2 Dual-Core Atom
  1. #671
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by l1nk View Post
    Moreover, the mic volume on output section was hidden; I found it hitting the right arrow as you said.
    I figured that would end up being a big reason as to why you didn't see it and try it. I was shocked at first that there was no option until I saw those little arrows.
    Tidder
    Try RevFE
  2. #672
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Still have an issue on this microphone problem... I'm not sure if it is due to motherboard software or riderunner itself.
    I muted the line as you suggested but everytime I use volume controls on rr mixer, expecially when turning volume up starting from zero, the muted line automatically unmute itself!
    I tried to look for a rr command to mute permanently some line and found the "exec;mute" that maybe can help. Don't know where to use, I'm still trying to understand why the muted line unmutes itself with no reason and no request by me!
  3. #673
    Feb 2008
    Has anyone found an adapter for the S/PDIF Pin Header with or without wiring ? I would like to connect to it for a coaxil output to a 5.1 decoder that I found. Maybe there is an coaxicial back panel header that plugs right in and rides on top of the S-Video.
  4. #674
    Feb 2008
    Oh Never mind it looks as though I can retask the back panel audio connectors using the Intel Express Installer CD-ROM. But then I would lose a Mic jack. Hmmpf.
  5. #675
    Jan 2009
    Quote Originally Posted by Technoid View Post
    Simple soldering job, if you want digital coax output (not optical). Take any typical 2 pin cable (HDD activity, power on, reset etc), solder an RCA jack on the two wires and plug them in to the rightmost (looking from the back of the motherboard) two pins of the spdif header.
  6. #676
    Feb 2008
    The 2- Pin cable is what I am looking for. The header looks specific.
  7. #677
    Jan 2009
    The header has standard 0.1mm spacing. Take any old front panel LED/power switch/reset etc cable and chop off one end.
  8. #678
    Feb 2008
    Thanks !
  9. #679
    Mar 2008
    Australia
    Is there any way to get a line in if i am already using the three audio jacks? (front rear sub). I need a line in for DAB radio.
  10. #680
    Feb 2008
    Quote Originally Posted by blade828 View Post
    You could check to see if there is a header for front audio jacks?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
