Soooo, I take this as a no.Guess I'll trash the cheap HD and get another solution for FM radio.
I've had my HD radio installed for a few months now. Besides have bad reception, which I'm working on (Got the metal case for the PSU), lately all I get is static for about 10 minutes, then the stations slowly start coming in. I starting to think I got a defective unit, or maybe this is why they are $40 on eBay.I know it isnt the antenna. Anyone else having or had this problem?
I'm still suggesting the power antennae thing. I had TERRIBLE reception on my previous radio setup with the stock antennae. Then put 12v on that blue wire and WOW. It said in the book that the blue wire was for "power antennae" and I was like, well, I don't have one that goes up and down, so that can't be it. But realized after looking at a schematic for the wiring, that it means amplified antennae. After hooking it up (the head unit powered it before which is why it died when the head unit was removed), the Visteon had better reception than my head unit or any other radio I've used. It blew the HQCT away.
So before you give up, please put a DVM on the blue wire in your harness and see if it has 12v.
Do you have like a $30 radio shark you could check that out with (stick the antenna connector in the hole)? If it is the Visteon, then you definitely have a bad one. I can get Dallas from Houston on mine. I got mine for like $50 on e-bay, so they aren't ALL bad.![]()
My opinion is my own.
I stand corrected. On the Vibe, it appears it's a black wire.....and it looks like there are 2 of them. One for the amp and one for the antennae.
2003 Pontiac Vibe Car Radio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: White/Black
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Black
Car Stereo Amplifier Location: Under the front passenger seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Another idea.....
Is there anyone near you that also has HD? If so, swap them and see if it really is the Radio. You also could probably find people here (me included) that would be happy to test your Visteon against their own. Would keep you from spending twice.
Here is where I got that info:
http://www.modifiedlife.com/2003-pon...-wiring-guide/
Ok, this is messed up.I just looked at the wires at the cars connector and they are like what you posted. But, the two black wires, AMP and ANT power, are connected.
Now, the plug I have for the radio/speakers that plugs into the factory plug has a bluw/white wire thats amp turn on. Actually, NONE of the colors match on either plugs to one another.![]()
Connected? To what, a head unit? If so, is your head unit on and set to radio when the Visteon is on? I'm guessing that if you are using a head unit, you have to be in Aux when the computer is running, thus turning off the antenna. This is scary, but you might try hooking 12v ignition directly to that antenna. That's what I had to do. The scary part is the "black wire" thing. lol
