Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Boot up 3 times @ 800x600, 4th time at 800 x 480???
  1. #11
    Apr 2008
    Quote Originally Posted by RedGTiVR6 View Post
    EXTREMELY strange....it solved a number of other issues too...like windows randomly not finding a boot device.
    I dono if it's a bad processor or what...
    I think it was due to overheating
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    I don't believe so.
    I have a Stinger scroll fan blowing air across the processor in addition to the processor fan/heat sink, as well as having a floor standing fan blowing cool air into the area.
    The stinger scroll fan moves air at 54 Cubic Ft. Per Min.
    Using speedfan, I could see my core temps at 52-60 deg. c....warm.
    Swapped to a celeron....same core temps....never run into the issue again.
    Jan Bennett
  3. #13
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Where you using a dvi converter to vga with all the pins (high quality), or with about half the amount (normal quality), because in the technical doc. Of the d945gcl it states that some screens talks to the mobo and that cosecs the boot to be slower.
    Talking to the mobo could also explain why it changed to the other screen-resolution.
    I want the other screen-resolution, and have seen on the desktop that it can and that the false of the screen-resolution are changed by attaching a different screen.
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    That's a good point.
    I'm using a DVI-I -> VGA converter.
    This one is the one with more Pins.
    I'm not sure I understand your post though, are you saying that just having to use the converter means it's going to slow down the boot, or.....?
    Jan Bennett
  5. #15
    Feb 2007
    netherlands
    no not using the converter, but some screens effect boottime. Found it in the tech info of the d945gclf. See page 62 (3.9.1)
    http://download.intel.com/support/mo...35968001us.pdf
    Just found the same ting in the tech doc of the dg45fc (page 68):http://download.intel.com/support/mo...35964001us.pdf
    I am gone trie a dvi converter with all the pins, maybe i 'll get the 800x480 option.
    boot time down to 24 sec, but using the normal 5400 rpm disk
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    damn...24 seconds....I guess it is possible then....i've got some work to do....
    Jan Bennett
  7. #17
    Feb 2007
    netherlands
    i do use hibernate for that 24 sec
  8. #18
    _
    Mar 2004
    Little Elm, Texas
    Have you been able to get rid of that annoying CTRL + P prompt when booting? The stupid thing that allows for remote administration of the bios? The Management Engine stuff?
    Jan Bennett
  9. #19
    Feb 2007
    netherlands
    no, i did get the F2 away, changes in the ME made the intel bootscreen take 25 sec . Took out the battery and disconnected the power, after that it comes on in 7 sec.
    page 29-32 are for the ME, not everything is in the bois / ME of the dg45fc.
    http://download.intel.com/support/mo...bymenu_v09.pdf
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by rijk View Post
    See, my boot up sequence right now is as follows:
    Screen powers on -> Screen powers off -> Screen Powers on -> Intel Boot screen -> CTRL + P for ME screen -> Intel Boot Screen -> Windows starts to load.
    If I could get rid of the power on/off cycle, one of the intel boot screens and the damn ME boot screen...I'd be EXTREMELY happy.
    What screen are you using for this? Your final carpc screen or just a screen on your test bench? I never had this issue when using the mobo on the test bench...well, I did have the ME boot screen, but not the other two issues,
    Yeah - there's really nothing in there that tells you how to disable it. I want to know how to disable it, or just remove it from the system all together.
    Have you had any luck with the DVI-D -> VGA adapter by chance? I'm wondering if that might also help out some....
    Really, an 8" VGA touch screen with a DVI input would be ideal....
    Jan Bennett
  1. Boot Times on XP
    By kundanp333 in forum General Hardware Discussion
    Last Post: 09-17-2008, 11:50 AM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  3. Replies: 2
    Last Post: 01-31-2008, 03:15 AM
  4. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 10:57 PM
  5. boot times for mp3 players
    By alany in forum General Hardware Discussion
    Last Post: 12-16-1999, 01:09 AM
