Results 1 to 10 of 17
Thread: Wireless Access Point Signal Boosters
    Constant Bitrate SuperAJ's Avatar
    Aug 1999
    Hey guys,
    Has anyone had any experience with wireless access point/router signal boosters?
    I am looking specifically at the Linksys WSB24.
    http://www.linksys.com/products/prod...id=38&prid=478
    It has +14 dBm peak gain, +20 dBm receiver gain and max +20 dBm Tx input power. I honestly have no idea what those numbers mean. I am trying to get the signal to reach inside of my car in my driveway. I can connect the Mp3Car to the wireless network when the trunk door is open, but not when it's closed.
    I've also heard about signal boosters you can make at home, but it seems like they have to be pointing in a certain direction to boost the signal. Any help/advice is greatly appreciated.
    Jul 2002
    Depending on what AP you have, it might be possible to attach an external arial on the outside of your house.
    Best regards,
    Matthew
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Build an antenna out of a Foldgers coffee can. Works very well, and quite cheap.
    May 2000
    Ft Gordon, GA
    hey aaron could you either go further into detail or post a link for more info on the cofee can antenna? thanks
    "if everything is under control, you're not going fast enough!"
    Maximum Bitrate freestyler's Avatar
    Jan 2002
    Chaska, MN
    do a google search for cantenna or pringles antenna and you'll find all the info to make them.
    the linksys product is a short range amp, if your access point is located on the opposite side of your house you will still be pushing the limits into your carputer, what type of card are you using in the carputer? if it's one of the usb ones you won't get even get close unless you do like aaron said and put an antenna, but even still you will be lucky to get the signal.
    1997 Jeep Wrangler Rugged Waves
    Ebay Stuff For Sale
    Aug 1999
    Thanks for all the help everyone. It's a linksys USB wireless adapter in the car. The Carputer does get a signal when the trunk door is open.
    I think I will experiment with the cantennas. Does anyone know if installing a cantenna will affect the range of the signal in areas of the house the cantenna is NOT pointing towards?
    Apr 2002
    North Yorkshire, UK
    The cantenna's are ratehr direction, you would most likely be best with an omni-directional antenna. There are a few of those DIY guides around for that type too.
    Look at: www.ackers.org.uk under the antenna section for some good links.
    War driving is not a crime
    Dave
    Aug 1999
    Alright! Thanks for the links!
    I think this will be my next project (budget willing).
    I've also wondered, I know that MAC Address filtering (where only certain MAC addresses can access your WAP) is a good form of security. WAP Encryption is a bit of a hassle. Is the MAC address filtering enough to keep out unwanted wireless network connections? I know that it is, but I want to hear some opinions since it really seems sorta simple.
    Apr 2002
    North Yorkshire, UK
    Im going to do this one:
    http://wireless.gumph.org/articles/homemadeomni.html
    Wonderful write up, part numbers for everything and full instructions.
    You link doesnt seem to work for me.
    Dave
    Jan 2002
    Chaska, MN
    no it isn't enough, mac spoofing is the simpliest thing to do, if someone was running kismet or ethereal they'd have all of the auth'd macs so it would be pointless, just turn on WEP (not WAP ) and disable SSID broadcasting for starters.
    Ebay Stuff For Sale
