Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 56
Thread: Full size HDD...reliability concerns?
  1. #11
    Mar 2006
    Colorado, but Canadian!
    which would mean you would have to go even faster than that. So I should ammend it to "hit a brick wall at a minimum speed of 7672.7mph"
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Newbie jongscx's Avatar
    Aug 2008
    thank you... :-P
  3. #13
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Yup hard drives are more durable than you or the car....
    TruckinMP3
    Read the FAQ!
  4. #14
    Mar 2005
    Well my hdd died. I am looking at getting a SSD now as their prices are no longer ridiculous.
  5. #15
    Jun 2002
    Colorado
    Quote Originally Posted by sxott View Post
    Right, but why did it die? I have had drives fail on the desktop and not in the car.
    Sometimes you get a short life drive.... do not blame the car automatically.
    Could be:
    bad power.
    an undetected fault when the drive was built.
    possible but rare poor install/mount and motion related.
    Really one of my drives survived 3 car wrecks while in use, two of the cars did not. They are generally very durable. I do not recommend testing this personally.
    TruckinMP3
    Read the FAQ!
  6. #16
    Dec 2006
    India
    Well... the 350G is non-operational shock for a 3.5" HDD. Operational shock tolerance is much less. It is around 68G. Not a small number anyways.
    Basically 2.5" drives are much much more resilient to shock and vibes...Typical specs as below.
    2.5" HDD: 350 g @ 2ms (operating) / 900 g @ 1ms (non-operating)
    3.5" HDD: 68 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
    I work for a company specialised in Automotive, Locomotive, Aeronautic Digital Video Equipments with some of the products having 2.5" and 3.5" HDD's for video storage. We have technical tie-up with major HDD manufacturers and we have discussed this shock and vibration issue in length with them for size and cost optimisation
    End Result: All our products employing 2.5" as well as 3.5" HDD's are shock mounted with wire-rope isolators. This is essential for us to meet our product MTBF numbers of 125,000 hrs.
    Carputer use: If you can afford some sort of shock mounting for the HDD, it always benefits.
    But according to our vibration tests, modern drives can reliably withstand most of the shock and vibes a car sees in a day to day use even without any shock mounting but the HDD reliability will be reduced to say...5 yrs or so...With HDD prices at the current low levels, do you even care?
  7. #17
    Oct 2006
    drives are quite durable under not too cold conditions, but when it goes pretty cold they're reliability goes way down. My drives survives basically 1 winter each time, then usually by springs i have to replace it with a new one. Considering SSD soon since its only down to 150/32gb now.
  8. #18
    Jun 2002
    Colorado
    Quote Originally Posted by DigitalVampire View Post
    SNIP
    Pardon me but this does not match our collective experiance.
    Several members report well over 5 years of use and I would encourage you to carefully define what you mean by shock mounting.
    Because a hard mount to the vehicle has proven to be very reliable while incorrectly shock mounting can potentially (maybe even likely) make motion related failure occur.
    TruckinMP3
    Read the FAQ!
  9. #19
    Jun 2002
    Colorado
    Quote Originally Posted by Punky View Post
    I would suggest finding a drive that does not use Fluid Dynamic Bearings (FDB)
    It is a feature to reduce audible noise in HDs but has trouble in cold temps.
    TruckinMP3
    Read the FAQ!
  10. #20
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Strange, I have also killed several regular hard drives after exposing them to the winter chill. They were free though, so oh well. But my automotive grade drive has been extremely resilient to both shock and temperature. I just bought the new Seagate ee25.2 80gb automotive grade drive, so if anyone wants my old 20gb ee25 one, send me a pm. Its still under warranty until 2011.
  1. will the 2699 fit full size drives?
    By DSM97RS in forum General Hardware Discussion
    Last Post: 03-11-2004, 01:07 PM
  2. Full Size Carputer..How to power it?
    By Otha in forum Power Supplies
    Last Post: 02-16-2004, 09:59 AM
  3. Cool Remote Control Full Size Vehicle!
    By jzgt in forum Off Topic
    Last Post: 10-18-2003, 01:54 AM
  4. full size color laptop display?
    By hfracing in forum LCD/Display
    Last Post: 05-29-2001, 02:56 PM
  5. Click here to find the best prices on full size LCD's
    By DodgeMp3Enabled in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:52 PM
