I should have been more specific.
Sorry...I was not talking about home brewed shock mounting schemes...It may work too, but as you've pointed it out, it may have negative effects since a badly designed shock mount with poor damping can amplify the shock/vibration to a catastrophic oscillation.
Over the years, we have received engineering samples of various shock mounting options from various HDD manufacturers ranging from simple rubber grommets, Teflon Posts, damping foam pads... to complex weighed wire-rope isolators. During the shock & vibration
testing, it was observed that any form of professionally designed shock mounting mechanism have a positive impact on the drive life and also on the data r/w speeds..Some better than the other...
I'll see with the concerned staff if I can post the information of some products we have tested...Most of the time they are samples shared under an NDA. I hope some of them might have matured to reach public domain by now, but I'm not sure on what is available in the market.
I dont have field data for hard mounted HDD's since we dont use that scheme in any of our products. We have come to this conclusion after consultation with the Engineering Dept of atleast 2 major HDD manufacturers. We would have loved to hard mount the HDD's and pocket the 30% of storage costs we currently spend on shock and vibration damping.
The 5 years that I've mentioned was just an approximation...I have also seen hard mounted HDD's fail in less than 48 hrs under continous vibration levels within the manufacturer recommended levels...Another important parameter is data R/W frequency. A typical OS/Data drive will not see reads/writes in a contionous fashion, but our test application writes to the HDD continously to mimic the real world HD
video recorder usage. An automobile may never see such vibrations nor a CarPC see sustained data rates and the drive could theoretically last longer. YMMV
