Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 56
Thread: Full size HDD...reliability concerns?
  1. #41
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by cougarz View Post
    just for statistics: today i lost my 3,5" 250gb seagate desktop drive. It was mounted horizontally, dumped with 4 springs and some foam. Before i mounted i tried to simulate some bump and i saw the spring/foam system dumpening it quite well.
    I live in italy, i had some bad start this winter when temperature goes under -3C. Now i still can look in some folders, but he's dying, every day some folder is not more accessible (acced denied). I will check sectors and so but i guess the baby has gone.
    My next buy will be probably a 2,5" dumped like last one.
    Springs make it worse. Instead of 1 bump, now you have 1 bump, 1/2 bump, 1/4 bump, 1/8 bump and so on depending on the spring itself, but basically you are making 1 bad bump into multiple little ones.
    1.9in x 2.9in -- 47mm x 73mm
  2. #42
    Nov 2005
    even if it's well dumped? Do you suggest to mount it directly to car frame?
  3. #43
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I think you mean damped. This mounting option may have "CAUSED" your failure by making the motion worse.
    The engineers at the auto company made your car suspension for a reason. Let it do the work for you. Mount the Hard Drive firmly to the car.
    TruckinMP3
    Read the FAQ!
  4. #44
    Nov 2005
    ok i will trust you and mount it rigid!Thanks!
  5. #45
    FLAC WuNgUn's Avatar
    Sep 2007
    Mount it vertically as well, not flat horizontally!
    If you mount it flat, it's mounted on the same plane that the heads platters are, making more likely that the heads will come into contact on harsh bumps...
    If you mount it vertically, your removing this scenario almost completely out of the equation.
    I once used an OmniFi MP3 player in the car...they also reccomended vertical drive mounting...
  6. #46
    Jun 2002
    Colorado
    Quote Originally Posted by WuNgUn View Post
    With lots of examples for orientation, we, the MP3car community has ZERO consensus on orientation.
    My view for what it is worth, mount it firmly in whatever orientation works for your install and never look back.
    From what I have read it is far more common to have other issues.
    Loose connections
    mismatched parts
    driver conflicts
    power supply issues
    Poor install practices
    matching the OEM look.
    If you plan and execute carefully you will minimize your risks of the issues mentioned above.
    TruckinMP3
    Read the FAQ!
  7. #47
    Newbie jongscx's Avatar
    Aug 2008
    hold on... mount it firmly or on dampeners?
    Firm and it'll vibrate as much as the car... Badly dampened, and it could shake even when the car's not anymore...
  8. #48
    Jun 2002
    Colorado
    Quote Originally Posted by jongscx View Post
    Firmly.... I believe I have been consistent on that point.
    TruckinMP3
    Read the FAQ!
  9. #49
    Mar 2006
    Quote Originally Posted by TruckinMP3 View Post
    Dampen it and you make it worse. Much worse unless you do it properly. A spring is very very very bad.
    Best bet is to use a smart drive with an accelerometer so if at Gs > threshold, park head type logic.
  10. #50
    Nov 2005
    uhm..i just ordered a 5400.4 but i see it has not this feature. It seems the 5400.5 has it, a bit more expensive but also more capable (320gb). If this is more safe i will go for it and change my order. Can you please confirm that what i said is true? Thanks
  1. will the 2699 fit full size drives?
    By DSM97RS in forum General Hardware Discussion
    Last Post: 03-11-2004, 01:07 PM
  2. Full Size Carputer..How to power it?
    By Otha in forum Power Supplies
    Last Post: 02-16-2004, 09:59 AM
  3. Cool Remote Control Full Size Vehicle!
    By jzgt in forum Off Topic
    Last Post: 10-18-2003, 01:54 AM
  4. full size color laptop display?
    By hfracing in forum LCD/Display
    Last Post: 05-29-2001, 02:56 PM
  5. Click here to find the best prices on full size LCD's
    By DodgeMp3Enabled in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:52 PM
