Results 1 to 7 of 7
Thread: Problem with PC powering down
    Low Bitrate Ricksastar's Avatar
    Dec 2007
    CT
    hey guys,
    i have a acc. for the computer that turns on and off with the ignition... i found a power source with the old radio wire harness. WHen tested it does deliver power when key is on and does shut off when key is off. yet when i shut the truck off the computer just does a hard restart. Then i have to wait for it to boot up and shut it off manually through the windows start button. I am using the m2-atx and i am %99 sure i have the jumper in the right spot...
    thoughts?
    Rick
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    For one, you really shouldn't be using stock radio wires for a CarPC; they usually aren't rated high enough for the amps a carpc can draw, and you're risking an electrical fire there.
    As to why it's restarting and not shutting down, it wouldn't suprise me if you're pulsing the power wire from something else that's on the same power line as the radio harness (check your car manual to see what else is on that fuse, for example.) Some things in a car, like the guages or the heater fan, can pulse a charge back once the ignition is turned off which, however small, might be confusing your m2-atx.
    Dec 2007
    CT
    so i should try another acc. location?
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    Do you have the pins from the m2 to the mobo going to the power button and not the reset button?
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    you should really run a power wire directly from the battery.
    and only use the ACC wire as a trigger, powering a relay if you want the power switched.
    as well as
    Dec 2007
    CT
    i am running the power wire from the battery. As for the acc. wire.. when i remove the wire from the keyed acc spot.. it shuts down like it should but if i do it with the key it restarts.. i double checked the pins and all is good
    Oct 2007
    Auckland
    ahhh... look for another acc wire, like the cig lighter one to test.
    as someone said there could be something weird on that same acc source.
    put a meter on the acc and see if it drops to earth when its "off"
  1. Vibration/shock pc problem - not the HDD
    By hondapc in forum General Hardware Discussion
    Last Post: 12-30-2006, 05:08 AM
  2. Powering a PC, Poweroff??
    By dusty_nz in forum General Hardware Discussion
    Last Post: 11-30-2006, 11:54 AM
