Results 1 to 5 of 5
Thread: retro installing Sata drive
    Sep 2007
    Hi all
    I've set my pc up with an ide drive with all my software and it is working fine.
    i managed to liberate my old PSŁ 40gb Sata drive and connected it up, and whilst its being recognised in bios/post, XP (on my ide) does not recognise it.
    I know i need to install drivers, but am unsure how to, as it asks me to install the drivers to a floppy (my carpc doesn't have a floppy drive)
    any ideas??
    Thanks all!
    Jul 2008
    Detroit
    I believe you can slipstream the drivers into an n-lited XP install. Is this going to be a boot drive?
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    copy the drivers onto a usb flash drive..
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Woofnstuff View Post
    No versions of XP that I have (legit original, legit SP1, and... others) support loading SATA drivers off of a USB drive during an XP install.
    So if you want to make the SATA the boot drive, you will need either a slipstreamed install disk or a floppy drive and disk.
    If you want the SATA to be a secondary, then you just need to get the CD that came with your mobo and grab the drivers off of it (or download from manufacturer's website) while booted into windows, install, and reboot.
    Also you can see what mode the SATA is on in the BIOS. Change to IDE if you can and still have the problems.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2008
    Detroit
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. My hard drive situation
    By PhatHam in forum Newbie
    Last Post: 10-26-2006, 01:50 PM
  3. Hard drive shock / vibration thoughts
    By S11D336B in forum General Hardware Discussion
    Last Post: 09-27-2006, 12:40 AM
  4. Western Digital buyers beware!
    By tj!2k4 in forum General Hardware Discussion
    Last Post: 11-26-2005, 01:17 AM
  5. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
