heres the thing--high res cameras are available, but there is a cost to them-- less recording time, and you would also need a recorder that uses less compression. it is as much about what cameras you pick as what recorder you use, and how it compresses, and processes the footage.
most people that install a camera system want to go back as far as possible--for referance, a 16 input dvr using mpeg4 compression, 70% image quality(larger saved pixel area), and 320x240 resolution, 7fps and 1tb drives will net you at least 30 days recording-- to alot of businesses, anything lower than that is unacceptable
on the same system, raise the frames to 30fps, raise the quality to 100%(smaller saved pixels), and change to 640x480 res., and you can expect recording to drop down to at least 15 days-- so just a small amount of changes, and you would need 2 tb to get back near 30 days. (keep in mind that the image is still getting compressed all this time to save on recording space, at the cost of image quality)
now just imagine the amount of recording space that someone would need to get something similar to even 720 res in uncompressed format. there is a very small market for systems in that cost bracket- most would probably end up going to Vegas Casinos....(though ip cameras are quickly changing the rules...)
on a cctv forum, i read a post a while back on what type of camera it would take to get resolution shown on tv shows 'surveillance
video recordings'--the color chip on the camera would be need to be near 5 feet across-- most standard cameras use 1/3" chips...
i laugh every time they 'enhance' a camera to read a licence plate that was 3,000 feet away, pointing towards the crime scene, and not looking anywhere near the building it was supposed to be monitoring...
in real life, the only way i can get a readable licence plate catpure/ or facial recognition is to put a camera over a small, narrow area that they MUST go through, and zoom the lens in where i expect them to be(usually overhead to get suspects/cars of different hights).
granted, there are cameras on the market that are designed to be dedicated for this, but most smaller companies do not want to pay that much for a camera that will only see a liscence plate/face...
sorry, i am kind of venting at what people have come to expect from cameras after watching shows like csi...
