Page 12 of 12 FirstFirst ... 23456789101112
Results 111 to 119 of 119
Thread: Low power consumption 24/7 video recorder?
  1. #111
    Nov 2009
    I've had this on my bookmarks for about a year, I'm still interested in putting a 24h surveillance system on my car, any ideas on a good reliable system?
    Regards
  2. #112
    Jun 2010
    Quote Originally Posted by Tech9 View Post
    Regards
    It depends on what you want to accomplish. My goal was to capture anyone who entered the truck. In that case, if you are sure to use low draw equipment, you should be able to leave the vehicle unattended for about 5 days to a week without killing the battery. I ended up not installing it because I couldn't figure out a way to put the alarm on a delay. I can't picture people entering the vehicle with three sirens, including one in the interior, blaring. This negates the purpose of interior surveillance.
    If your goal is to add exterior surveillance, you'll need multiple cameras, 1 or more DVRs (many are 2 or more channels), and likely a second deep cycle battery to avoid killing the car after a day or three. You could trigger the cameras off either motion or an alarm trigger. Take an output from your alarm, run it to a relay, and then use that to switch your DVR and cameras on and off. The downside to this however is that you'll have a few to several second delay as everything comes online.
    If you end up installing something please post some details.
  3. #113
    Nov 2009
    Quote Originally Posted by LMB68 View Post
    What I was looking for at the time was 4 cameras, 1 on the back, 1 on the front, and one on each side. It would be for 24h surveillance, to catch something like this in case it happends:
    [media]http://www.youtube.com/watch?v=CPyYZ52IXYg[/media]
    Regards
  4. #114
    Jun 2010
    You could get something like this: http://cgi.ebay.com/Mini-4-Channel-R...item1e5d1201c4 and four cameras. I'd probably use a relay to either turn it on when the alarm is activated or when the motor is off. You could also add an override switch to leave the system on whenever you want such as when you drop the car off for service.
    You'll probably need to add a deep cycle battery to prevent killing the battery.
    On another note, it looks like that Hummer was parked in a handicap spot. In the second shot, the parking space below it appears to be blue. lol
  5. #115
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    topic still seams to be popular
    in the beghining of the next year im planing to do my own 8 camera DVR (digital cameras, small size like in your phones) that would suport 48 hours engine off monitoring + gps + shock sensor + 60fps (or maybe 120fps) while we are moving + real time viewing on the web with gps tracking and camera images feed.
    Well that all i can dream off but proce wont be as pleasant as that uniton ebay
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  6. #116
    Nov 2009
    How much do you think a system like this would cost, including all material needed.
    Nov 2009
    bump
  8. #118
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    If you look at the previous pages, I've outlined a system that works perfect.
    A multi-channel hard drive based DVR will most likely NOT work for 24/7 use because the power consumption is too high. You can run it off a big deep cycle battery, but you also have to keep in mind that lead acid batteries take time to charge...so unless you drive for hours and hours each day, you probably wont be able to keep the deep cycle battery topped up.
  9. #119
    Jun 2007
    New York
    he can combine LiPo + Pb battery and that will solve charge tyme problem but will increase complexity
    I have something on my desk now that might be useful its 4ch dvr running of single LiPo it works about 3 hours of 720mA battery... I have 5200mA battery aybe this will work in the car too
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 02:35 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. onboard video vs a video card, power and cpu usage
    By stapan in forum General Hardware Discussion
    Last Post: 06-09-2005, 03:43 PM
  4. Keeping Power Supply on 24/7 ?
    By homep1 in forum Power Supplies
    Last Post: 06-07-2005, 03:42 PM
  5. Looking for low power 24/7 Bluetooth Capable Computer
    By psuter in forum General Hardware Discussion
    Last Post: 03-28-2003, 04:52 PM
