Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 119
Thread: Low power consumption 24/7 video recorder?
  1. #11
    Constant Bitrate kwchan's Avatar
    Dec 2006
    Singapore - Smallest country in Southeast Asia
    looking at something that can record in DIVX @ 30fps, preferably support >4GB SD card
    The DVS can only record 8fps in AVI format
  2. #12
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Well, I couldnt find any better system that would meet my needs of low power consumption and automatic loop recording. So I just pulled the trigger and bought the sd dvr:
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=012
    and a cctv camera (I hope those are real ir leds):
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=018
    Also bought some lm317 voltage regulators so that I can hook them up in the car. Total cost is just a little over $100CAD. The whole system should draw under 5 watts and will be run from my auxiliary deep cycle battery. Although having a high frame rate would be great, I think I will just set the system to automatically take pictures when there is motion. Hope this works.
  3. #13
    Dec 2006
    great...can post some sample video once u got it?
  4. #14
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Sure, if I remember. It's shipping from China...so will probably take a while.
  5. #15
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I was wondering if any electronic gurus would have a good recommendation to efficiently regulate the voltage from 12v to 9v and 5v to power the recorder and camera. I am most familiar with the lm317 chip, but that seems to dissipate the extra voltage as heat. I would prefer something as efficient as possible. Every watt counts, as I am running on battery.
  6. #16
    Oct 2006
    Not sure how efficient your chips are but these guys are designed for decent efficiency.
    http://www.hvwtech.com/products_view.asp?ProductID=585
    company is also located in calgary as well.
  7. #17
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Thanks for the info, thats exactly what I am looking for. Although I will probably try eBay for some cheaper adjustable switching type regulators.
  8. #18
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ok everything just came in, so I thought Id give a update and share some footage to demonstrate this setup.
    Dont have time to install it in the car yet, so I just slowly swept the camera around my computer area. The device can be setup for motion detection and record video or take pictures. I have attached to this post what it looks like with the cheap eBay camera attached. Ive attached both captures in video mode and picture mode.
    I also wanted to measure the power consumption, but it maxed out my multimeter. So I attached a 1ohm resistor inline, measured the voltage drop, and calculated that the camera + dvr consumes about 3.1W @ 12V.
    Attached Files Attached Files
  9. #19
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I definitely think perhaps my cheap camera is the limiting factor for this setup. I have hooked the device directly to a cable box, and you can see the quality is noticeably better. I have attached the video and pictures of when the input is from a cable box. Although I can set it to record at 30fps, right now its set at 5fps to save memory.
    If anyone has suggestions on how to improve this setup, comments are welcome.
  10. #20
    Sep 2007
    West Springfield, MA
    It does seem much better with the cable setup vs. the camera. Even still, I don't think the camera is horrible. Much better than any security footage I've seen.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. onboard video vs a video card, power and cpu usage
    By stapan in forum General Hardware Discussion
    Last Post: 06-09-2005, 03:43 PM
  4. Keeping Power Supply on 24/7 ?
    By homep1 in forum Power Supplies
    Last Post: 06-07-2005, 03:42 PM
  5. Looking for low power 24/7 Bluetooth Capable Computer
    By psuter in forum General Hardware Discussion
    Last Post: 03-28-2003, 04:52 PM
