Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 119
Thread: Low power consumption 24/7 video recorder?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I was wondering if there exists a video device that could record 24/7 but draw very little power? Would also be nice if the device could automatically delete older footage to make room for new footage...thereby making the device practically maintenance free. Hopefully can store atleast a day worth of video.
    I could easily rig up the carpc to do this, but the high power consumption makes it unfeasible for 24/7 operation.
    What do you guys think?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Bump...ok maybe ill lower my expectations a bit.
    I dont necessarily need a 24/7 device, but maybe something that draws under 10watts that I can leave recording for 8-10hrs a day while I am at school.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    When i had looked into it in the past, I saw some flash bashed DVRs on ebay that weren't horrendously expensive.
    Sep 2007
    West Springfield, MA
    What I would look into is something like a spycam. They make some now that use memory cards and write straight to the card. Usually, they're hidden in things like a clock, but you could take the circuitry out and do as you wish with it. Something like this:
    http://cgi.ebay.com/ebaymotors/Motio...QQcmdZViewItem
    Apr 2005
    Boston, MA
    This looks promising except for the record length
    http://www.4hiddenspycameras.com/podivire2tft.html
    Portable Digital Video Recorder 2.4" TFT Monitor (Schedule Recorder & Overwrite)
    Rechargeable battery Powers the covert camera direct using the same power and rechargeable battery built inside, stamps date and time, schedule recording system (Time and date) , supports 4GB SD memory card for 3.5hrs of video recording time, 2.4 TFT color monitor, resolution VGA 30fps real time recording, Compression MPEG-4 Format, PC interface (USB2.0) and more.
    Specifications:
    MINI Mobile Digital Video Recorder
    SD/MMC. card slot (support up to 4GB)
    date and time stamping
    loop overwrite record or continuous record
    Extend Interfaceirect supply DC Power 9V output for Camera and Video composite input
    Special Power save button (monitor sleep mode)
    Display : 2.5" LTPS TFT LCD 960x240,230K
    AV recorder resolution : 640x480(VGA) / max 30 fps.
    Adapter : 5V DC adapter (USB port) / USB cable
    Dimension:95.5mm x 63.5 mm x 21 mm
    Schedule record.
    3 level of selectable recording timer from 1 minutes to 240 minutes (4 Hrs)
    Overwrite.
    Settings REC MODE Continuous ( REC loop duration that continuously overwrite records to SD data storage)
    Standby
    Settings power saving star time 2,5,10 min.
    Apr 2005
    Boston, MA
    Here's another, a bit pricier, but 4channels and 300+ hours
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Thanks for the suggestions. I guess I have been using the wrong search terms on eBay all along. Ill keep looking and see if any of them suit me. I think the only features I really need are automatic write over and low power consumption.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ok so after a bunch of searching, I found this:
    http://cgi.ebay.com/DVS-Digital-Vide...QQcmdZViewItem
    Very cheap and even includes 2 night vision cameras. Also maintenance free since it automatically loops over old video. Might be difficult to hide the camera in the car though.
    Any opinions on why I should not just go ahead and buy this?
    Apr 2005
    Boston, MA
    Quote Originally Posted by nobb View Post
    Certainly cheap, I wonder how good the video quality is. 2GB isn't going to hold a lot.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    ^Well it appears to be the same as this unit:
    http://cgi.ebay.ca/USA-DVR-Camera-Vi...QQcmdZViewItem
    Video resolution is 320 x 240 and picture resolution is 640 x 480, so I suspect it would probably be better to use automatic picture mode. Reading the specs on similar looking units on eBay, apparently the device can record 4380 videos. Each video is 10s, so doing the calculations, it means the device can store 12 hours of video. That should be more than enough because it only records when in motion.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  3. onboard video vs a video card, power and cpu usage
    By stapan in forum General Hardware Discussion
    Last Post: 06-09-2005, 03:43 PM
  4. Keeping Power Supply on 24/7 ?
    By homep1 in forum Power Supplies
    Last Post: 06-07-2005, 03:42 PM
  5. Looking for low power 24/7 Bluetooth Capable Computer
    By psuter in forum General Hardware Discussion
    Last Post: 03-28-2003, 04:52 PM
