Results 1 to 5 of 5
Thread: Serial Port issues, can someone help?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I just got done doing a reinstall of Windows. I am now installing all the devices back in, but I am having major issues with my serial ports. I attach XM, HD Radio, OBD scanner, and AMPCTRL, which are all serial and they work off and on, but most of the time they dont. Maybe i have to flash my MoBo? When I connect XM it installs as a serial mouse, so I go to device manager and disable it, then restart and XM should work, but it does nothing. HD does the same also installs as a serial mouse which is disabled. I then go to Mitch's app and open it and it says no radio detected, but I hear the radio clicking. The OBD just seems to work when ever. The AMPCTRL seems to work perfectly though.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Mar 2006
    Colorado, but Canadian!
    You have 4 independant serial ports? Maybe time for a USB switchover...
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2007
    Miami
    Quote Originally Posted by 2k1Toaster View Post
    I dont know if they are independant.... There are 2 in the back of the MoBo, then 2 on the motherboard via header connectors. It doesnt make sense why they worked before the restore and now I have issues.
    PS: I did replace my USB PCI card with a new one, but that wouldnt cause issues would it?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    check the COM-number of them in device manager. when my USB GPS went automatically to COM15-20, the sw's are unable to connect it - i could select this number, but did not work. when i set it under 10, then it worked...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Jul 2007
    Miami
    I think this may be happening to me also. I uninstalled all the serial ports then unplugged all devices that use a com port. i then restarted and it installs the serial ports back to their original number, which is 1-4. I then tested with HD and XM, and it worked. So I then changed HD to 15, XM to 20 and left the OBD2 scanner at 3. All worked perfectly. I then decided to change it from 3 to 15 and all my headaches started again. So now i have to uninstall that one serial port then leave it at 3. Thing is my BT stack is also on 3 so i will just have to uninstall that.... and reinstall.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Bluetooth Serial Port Nightmare, IOGEAR, Zoom
    By matt621 in forum General Hardware Discussion
    Last Post: 07-05-2008, 08:55 PM
  2. XM solutions - no serial port available
    By FockMasterDan in forum General Hardware Discussion
    Last Post: 06-05-2008, 03:02 AM
  3. Sprint Touch BT Serial Port Trouble!!! Please Help
    By compman723 in forum Wireless Communications
    Last Post: 02-08-2008, 11:09 PM
  4. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  5. Can I pull out 200mA from serial port of Epia 10000?
    By slimmegane in forum Hardware Development
    Last Post: 10-24-2005, 11:25 AM
