Results 1 to 10 of 13
Thread: Where can I get a 4ga fuse block
    Jun 2008
    Hey guys where are all of your getting your 4ga splitter that has the fuse feature built into it? I thought Advanced auto would have something like that but they don't.
    Elsewhere
    Quote Originally Posted by mdawg View Post
    Try a car stereo shop.
    If you're willing to go with an online vendor, try one of these links:
    http://www.hifisoundconnection.com/S...FQyI1QodqF0VQw
    http://www.darvex.com/miva/merchant....egory_Code=FDB
    http://www.crutchfield.com/g_715/Pow...e.html?tp=3001
    How about the Wiki?
    Jun 2008
    Curious how important are the brands of these. Will any one of them work cause If so I kinda like the digital ones for show and power draw which are cheap on ebay http://search.ebay.com/search/search...ock&category0=
    Elsewhere
    Can't say. I have a Streetwires distro block that does both power & ground. I've never used a no-name brand, so I can't say.
    Considering you're talking about your vehicle's electrical system and the risk of a short & fire in your vehicle, is it something you're willing to gamble on to save $15 or whatever?
    How about the Wiki?
    Jun 2008
    bump?
    Jul 2006
    seattle
    one thing for sure, it would drain your battery faster than the standard distro block
    Also, I use knukonceptz cable, distro block (non digital one) and some other stuff they have. So far I am pleased with it.
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Quote Originally Posted by DarquePervert View Post
    How is a distro block going to cause a short or a fire? It's a block of metal. Just keep the positive block/terminals away from the grounds and it will be fine, no matter what brand is used.
    I would also like to comment on the fuse. Make sure that you aren't substituting the fuse by the battery for a fuse in the distro block. Your positive lead should still have a fuse within 18 inches of the battery.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Jun 2008
    And it will be...here is a pic I drew up of what it will look like and I also had another question which I added in the picture.
    Jul 2002
    Construction quality would affect the ability of the fuse block to keep the positive terminals away from the gound. You don't want something so cheap it could break and short out.
    Or it could get hot and melt or possibly cause a fire. You don't need massive amounts of current to do that. A bad contact in there (e.g. fuse to fuse holder) can get hot. 40A with a 1V drop is 40W. Think how hot a 40W lightbulb gets.
    If there is a bunch of extra circuitry inside, like the examples in the link with displays in them, how well is that made for such a low price?
    Elsewhere
    Quote Originally Posted by The Grinch View Post
    If a distro block is poorly manufactured, it could create a short. The addition of distro for both power & ground increases the possibility of a short. So does the additional electronics required to display foltave and/or amperage, as Alanh pointed out.
    Yes, I fully realize it's an extremely unlikely scenario.
    However, people thought that lead paint on children's toys made in China was an extremely unlikely scenario, too.
    There are some brands that have stringent manufacturing quality standards. There are other brands that don't care as much.
    Would you be willing to risk the safety of your ride to some brand you (or anyone else in the car audio hobby, for that matter) has never heard of or dealt with?
    For the additional $10, the peace of mind I would receive from purchasing a known reliable brand is well worth it to me.
    For future reference, it's A LOT easier to add the question in a post rather than the image.
    And you didn't really ask a question in your pic.
    But your diagram and logic is correct. You would use an ignition-switched line to trigger the relay, which would be between the distro block & the inverter. That would power on the inverter when you turn the key on, which is what I believe you ultimately want.
    How about the Wiki?
  1. Igniton Fuse Keeps Blowing
    By TeamRSX in forum Power Supplies
    Last Post: 05-06-2008, 11:02 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Replies: 11
    Last Post: 06-16-2006, 12:19 PM
  4. Aux Fuse Block
    By Dragonknell911 in forum General Hardware Discussion
    Last Post: 08-24-2005, 09:22 PM
  5. what gauge wire to run from fuse block to trunk?
    By MP3GTP in forum General Hardware Discussion
    Last Post: 03-30-2005, 05:17 PM
