why not just play genesis/mastersystem/game gear/megadrive on an emulator?
So, I've been searching around today and found that sega genesis power adapters are 120v in and 9-10v output.
How do I find out what the maximum voltage is that the sega can handle? I was thinking about hardwiring it direclty to my car. My car gets a peak of 14v while on, but mostly stays at 13v. How do I know if this is too much voltage?
I also found a car adapter for a game gear, rated at the same voltage but the current rating is different. The game gear adapter says 800ma while the regular sega pulls 1.2amp. So I don't think I can use it. Someone help me here.
Live mp3Car Facebook Chat
Because I have the sega just sitting here. Don't want to build a carputer for the car it's going in.
1.9in x 2.9in -- 47mm x 73mm
Any idea where I can get a regulator?
You could use a second car adapter for the Game Gear and wire them parallel to each other.
get a cheap inverter, simple and easy.
At present I am running an xBox off an inverter, but intend using a DC-Dc supply once I can get a second xBox to hack up and test.
I also have a Sega Megadrive (Genesis) which I have contemplated sticking in the car but have so far decided against.
Do they make "cheap" inverters?
Would this work?
http://cgi.ebay.com/FOR-CAR-POWER-OU...QQcmdZViewItem
I would want to hardwire it up to my car since the cig lighter is all sorts of in the way.
