Results 1 to 10 of 13
Thread: 5400 or 7200 rpm harddrive..
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    would drive speed make a difference in a carputer? like the system im building is for a jetway amd set up with a 1.4 GHZ processor with a 80GB 2.5 5400rmp sata drive...would getting a 7200 make a big difference? i mean..all i need it for music/video...the usual carpc stuff...its not like im going to do photoshop on it or play crisis on it...... music -video -dvd - visualizations..that it..not much more...
    Mar 2006
    Blog Entries
    1
    No, a 7200 rpm won't make a difference. I went from a 7200rpm IDE 60GB to a 5400rpm SATA 120GB drive and didn't notice a thing. Carpc aren't that demanding.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    in theory boot times and disk access will be faster with a 7200RPM
    BUT
    the faster it spins the more chance there is of a bump in the road making a bump on your disk, and more chance of losing data
    5400rpm sata is heaps fast enough for a car anyway.
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    5400 rpm hybrid (readydrive). Idle most of the time.
    My opinion is my own.
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    the higher RPM disk has higher inertia (i dont know, if its the proper expression), so its more secure in theory... but it depends on many thing, like its rotation/position, and others... so, i have a 7200 disc because its faster than 5400...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Sep 2007
    The hybrid readydrive uses a flash disk in conjuction with the harddrive, writing what is needed to the flash, then stopping the heads. So the 5400 rpm really doesn't mean anything.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by danielkh View Post
    there is no disk in flash memory.
    And the 5400 means alot when booting.
    Only time you will ever notice the difference is at a full boot, and during file transfers. Other times your disk is at like 1% average usage.
    1.9in x 2.9in -- 47mm x 73mm
    Sep 2007
    Built in Flash DRIVE....happy now?
    Actually, watching the harddrive light, it is a LOT different from a non-hybrid drive on activity.
    Mar 2006
    I meant the only difference statement on non-hybrid drives. Probably should have had some sort of transitional sentence in their too. Oh well. But yes the difference between a flash based hybrid drive and a good 'ol 100% magnetic disk are quite large. Also big differences in power consumption (if your OS supports it).
    Mar 2006
    Blog Entries
    1
    If you visit tom's hardware you can view a list of 2.5" hard drives with their read/write performance numbers, in there you'll be surprised some 5400 rpms are faster at delivering data than 7200 rpms. With hibernate cutting down boot times to mere seconds there really isn't a need for fast drives on a carpc.
  1. 5200 vs 7200 rpm HDD for storage
    By bl3nd3r in forum General Hardware Discussion
    Last Post: 06-13-2008, 11:11 AM
  2. Replies: 18
    Last Post: 09-18-2005, 02:00 PM
  3. 4200 vs 5400 rpm laptop harddrives
    By ZenerDiode in forum General Hardware Discussion
    Last Post: 01-23-2005, 05:28 PM
  4. 40GB 5400 RPM Laptop Drive for $69.99 after rebate
    By Supermike in forum General Hardware Discussion
    Last Post: 01-05-2005, 06:02 PM
  5. 5400 vs. 7200 speed hard drives
    By mykolJay in forum General Hardware Discussion
    Last Post: 07-12-2000, 11:31 AM
