Found a decent one at Staples and took it apart.
BELKIN F3U134VFLEX Flexible USB Cable Adapter
due to space constrain, I will need to find the smallest right angle USB connector
Tried ebay but the right angle connector seems to be quite big.
Anyone manage to find something smaller than this?
I hacked up a touchscreen on an Eee PC a while back and couldn't find a USB connector small enough, so I just direct-soldered the connectors. You could probably chop down the plug and splice as well, but in my case that was still too big.
DIY solution: buy a solderable USB A plug
cut the unrequired cable fixing flag on its back, solder and rotate the cable in right angle, then put hot-glue on it as isolation
when its temperature decreasing, you can form it with your fingers. i use this simple trick many times on several connector type...
"case": Skoda Superb Elegance 1.8T
Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
Pretty much any USB connector is solderable given an X-Acto knife. It's all wires.
thanks for the idea...what about shielding? It would be important since i will be connecting to a portable hard disk
I use silicone resin, usually. USB tops at 5V 500mA, so you can get away with using silicone sealant you buy at Lowes, etc. for bath and kitchen work. Glob it on, it's non-conductive and heat resistant to about 250 degrees.
Incidentally, why a portable HD? I can see taking your music from home-car-work, but AFAIK there's a speed hit especially if you're running the OS from it.
USB is self-grounding through whatever the mobo is grounded to, or the hub in the case of powered hubs.
