Results 1 to 4 of 4
Thread: Logic relay switch
    Apr 2002
    South Coast, UK
    Logic relay switch
    OK, so Ive got these great illuminated buttons (see here) which are "push to make". What I want is a schematic of a circuit that I can connect to a relay so when I press the button once, the relay switches on and stays on; when i press again the relay switches off and stays off until I press again to turn on. Does anyone have any ideas on a circuit that can do this simply?
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    try this. i just built it. i got it from it is a new kit for them -only in their catalog when i got it-not on the web page. you can call them. jumpers allow you to have relays "latch" on/off or momentary.
    Jan 2003
    Westland, MI
    you are looking for the DEI 611T latching relay - dearch the web for a supplier or I can get it for you if it is cheaper -
    Brian F.
    Sep 2002
    Just North of Toronto, Ontario, Canada
    Thats a neat compact little Transmitter/Reciever unit there alby.
    Ive found a source for those things in canada:
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
