Results 1 to 4 of 4
Thread: Mounting problem
    Sep 2007
    Sunny Florida
    Mounting problem
    Okay the other day I screwed my carpc case down not thinking at the time. After the fact I realized that the carpc was slopped in a 45 degree angle. I've read a few things about hard drives having to be either completely flat or completely vertical. I'm using a laptop hard drive though and was wondering if the same applies for a laptop hd?
    Elsewhere
    It applies to any hard drive.
    They all operate the same way and are subject to the same laws of physics. The only difference is size.
    How about the Wiki?
    Sep 2007
    Sunny Florida
    Quote Originally Posted by DarquePervert View Post
    That's what I figured looks like a ssd is the best way then
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    The old (I mean first generation drives) needed to be formatted in the orientation they would be used in. They had very large physical platters back then.... Modern drives are much, much smaller.
    Drives have not had that limitation for many years. I would not hesitate to put a HD in a car in any orientation.
    Edit: DP is right, same physics regardless of size. But a platter the size of a serving plate can flex more than a the 3.5 inch HD from a desk top. Additionally the materials science has improved as well.
    TruckinMP3
    Read the FAQ!
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. Problem with TV Mounting
    By KevinACrider in forum Fabrication
    Last Post: 11-09-2005, 02:17 PM
  3. Okay, screens are mounted, what is the problem now ?
    By SerbianBEAST in forum LCD/Display
    Last Post: 11-08-2005, 03:29 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 08:19 PM
