try to contact them:
http://www.dc2dc.com/store/store.html
they have the 55W for only $25...
the 90W is comming soon...
at europe you found this for 66 euro (=66 $)
http://www.diffusion-informatique.co...ue2/index.html
Also are aou using a std 5 1/4 cd drive? (they are eating +12V)
Morex use a slim cdrom that need only +5V
Raw Wave
Originally posted by Spongebob
well for some reason the hard drive doesnt even wind up like that. what i cant figure out is why i have been able to successfully boot up using the casetronics power supply a few times, but now i cant. there is no way that the epia board and 1 60 gig 7200 hard drive is pulling more that 55W. unless i have a defect? but nonetheless, it did work a few times.
Here's my findings about my setup I've been having issues with...
SETUP:
Casetronics DC-DC board and external PSU
EPIA-M 9000
IBM Laptop Travelstar 4700 RPM 40Gig HD
Pioneer 16x slot load DVD
256 PC2100 RAM
Fellows serial internet touchpad
Creative serial IR reciever
Griffin USB Powermate
M-Audio Sonica (USB sound device)
300W inverter wired to the battery
When I was setting up the carputer in my house I had no issues AT ALL for days. After the install into my car I started having issues, after about a week, with the carputer shutting off instantly when I would use the DVD after the carputer was on for about an hour. I added a 40mm fan to the southbridge because I thought the heatsink was getting too hot. A few days later it started shutting off after about 5 min. of DVD use when it was just booted up. A few days after that it started shutting off with just WinAMP playing for about 15 Min. Then it just wouldn't start at all. I would get an "electrical click" through the speakers but nothing would would spin up, not even the fans. The computer was not even warm during this time.
I was reading your other posts about the power light flickering when you would have the same thing happen to you but I never got the flickering light, it just stayed solid and as bright as when it was powered up normally. Anyway, this morning I took my center console apart (the carputer is installed in the arm rest) and disconnected EVERY DEVICE except for the HD and DVD drive. IT STILL WOULD NOT BOOT UP. I checked all the wiring and looked at the DC board for any burn marks. Nothing...I unplugged the two wire "bridge" from the DC board and plugged it back in. WHOULD YOU BELIEVE THE FLIPPIN' THING BOOTED AFTER THAT!!!
I did put a DVD in the drive and it had no problems playing it for a few minutes. I did not get a chance to test it extensively but I will on my way home tonight. I will post my findings then.
I'm not sure if it's the external PSU not being powerfull enough or something else. I did notice at CompUSA they had THIS Targus Auto power adaptor, that supplies 70W and it's about half the size of the PSU for the DC board, on sale for $75. I need to do some serious testing soon to get this BS finalized.
Two things you may concider.
Put a second one of the DC-DC in the case as it will probably fit being so small.
Run the drives off one and the mobo on the other.
Second option, overnight a modified Opus.
3rd option buy (and than return after you get back) an inverter and a temp standard atx power supply.
Not the best option, but neither is a 12 hour drive without entertainment...
-Mario
does anyone know if the opus or sproggy will fit inside the 2699 case? is there any other alternative to use other than that 60W dc board with the 2699?
Somewhere on the buy/sell someone was selling one of those cases with the Opus fitted inside.
One would think you could do the same with the 2699...
-Mario
Raw Wave
Raw Wave
I noticed you are using the M-Audio Sonica for audio output. Did you find the audio quality on the M9000 to be poor?
Is the Sonica significantly better?
-Chris
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
