Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: OCZ Core Series OCZSSD2-1C64G 2.5" Grab yourself a 64GB solid-state drive for $99
  1. #11
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    That's a bit disappointing...with SSD I would have thought you just use it like a normal drive. I guess the mainstream stuff still has a while to go before being practical and a suitable hard drive replacement.
  2. #12
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    I'm not surprised about writes being slow, as copying files to a usb drive is much slower than reading it. Are the SSD drives faster than say a CF hooked up to an IDE port?
  3. #13
    Mar 2006
    Blog Entries
    1
    USB memory stick works pretty good with large files, same goes for most MLC SSD drives. But as soon as you do a lot of small writes it chokes and EWF helps alleviate this problem. SSD drives may be a bit better because it has wear level algorithm, and it's optimized for hard drive use. Again the only SSD drive I would purchased today are SLC SSD or the new intel MLC SSD drives.
  4. #14
    Constant Bitrate vull's Avatar
    Oct 2007
    Quote Originally Posted by _dopehead_ View Post
    I read a test of the new intel x25 ssd compared with ocz and others, and there is some general issues with random-write/random-read on pretty much all of them except intel's new x25.
    Found the article, http://www.anandtech.com/cpuchipsets...oc.aspx?i=3403
    god damn :s
    six hundred dollars???
    PS: what's an ewf?
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. problems with navigation in streetdeck
    By customaudioman in forum StreetDeck
    Last Post: 01-25-2008, 12:46 PM
  3. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 02:20 PM
