damn....looks like they killed it
If you can dream it you can build it ( I think )
Build File
EWF, HORM, MinLogon on XP.
Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
Win Embedded Std 2011 RC
OCZ Vertex Turbo 30GB SSD
Lilliput 629 Transflective, WRX Screen Mount
BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
VoomPC 2
What do you mean killed it? It's still available from what I can see.
Look under the tab that says rebate![]()
Build File
it says deactivated item
Not very good reviews from people that already bought them...
I got rid of my SSD drive because the write speed was ridiculously slow, I see these drives suffer the same problem, slow write speeds.
Wow...so reading some reviews, it seems a common complaint is that when using this drive, the whole system becomes unresponsive when the drive is written on? Not good for multitasking....
I read a test of the new intel x25 ssd compared with ocz and others, and there is some general issues with random-write/random-read on pretty much all of them except intel's new x25.
Found the article, http://www.anandtech.com/cpuchipsets...oc.aspx?i=3403
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
Well with EWF you don't have to worry about it writing to the disk ever.
Yeah I used EWF on my MLC SSD drive and noticed a big improvement on bootup, need to avoid writes as they slow the drive down considerably. I had to get rid of the SSD drive cuz it would frequently and mysteriously lose it's partition data when connected to the D201GLY2A or D945GCLF motherboards. It worked flawlessly on my notebook, strange how it was hardware sensitive.
The only MLC SSD drive I would consider buying is that Intel version, or purchase only SLC SSD drives.
