Results 1 to 3 of 3
Thread: Power Inverter questions!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have a 100 watt inverter that currently is powering a powered VGA splitter. I want to add two 7 port hubs that I want to also power on the inverter. The MoBo is very picky and doesnt allow me to power anything off the 5V rail. So I wanted to use the wall adapters that came with the hubs. Is it possible I can power the VGA splitter, and both hubs off the one 100 watt inverter? How can I test?
    Here are the output stats on the inverter:
    12 VDC at 10 amps
    USB 5 VDC @ 1 amp
    The plug adapters are:
    Hub 1: 5 V at 1 amp
    Hub 2: 5 V at 1 amp
    Splitter: 9 V at 2 amps
    So technically I would be using 19 V at 4 amps, so I will be overloading the inverter?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by HiJackZX1 View Post
    uh... plug them in and see if it works?
    Jul 2007
    Miami
    LOL, I decided to leave the inverter alone and have it continue to power the VGA Splitter and PPC. I have a second inverter that is also a 100 watt inverter, I was going to use the USB port for Hub 1 and the plug with the hub wall adapter to power the other.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 09:12 PM
  2. FAQ: Power Supplies Explained (Part 1)
    Last Post: 06-10-2007, 08:45 AM
  3. Inverter low power alarm
    By vadik29 in forum Power Supplies
    Last Post: 03-07-2005, 08:01 PM
  4. Simple Idea for keeping power to inverter while cranking....
    By syclone477 in forum Power Supplies
    Last Post: 03-23-2004, 10:03 AM
  5. Inverter Power - Autoelectrical q
    By MerlinDaHapyPig in forum Power Supplies
    Last Post: 03-16-2004, 03:26 AM
