Results 1 to 7 of 7
Thread: Standby vs. Hibernate vs. Sleep
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Ok so far I know stand by shuts down only a few componets in a pc. Hibernate saves data to disk and then shuts down the pc and when restarted it picks up from where it left off.
    my question, is hibernate the same as s3?
    how do i enable it ( S3)..i turned it on my motherboard.
    when i hit the power button, it goes into hibernate mode. is this the same or is s3 a different state of being..lol..
    Elsewhere
    S3 is a standby mode.
    S4 is hibernation.
    How about the Wiki?
    Aug 2007
    Queens, NYC
    Quote Originally Posted by DarquePervert View Post
    S4 is hibernation.
    so what happens when I enter s3 mode?
    When it goes into hibernation mode, everything shuts off....
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    S1 - on
    S2 - sleep with more power, faster restore
    S3 - deep sleep with less power, but slower restore
    S4 - hibernation, power not required
    S5 - off
    to switch between S2 and S3, go to bios setup - but on some board, for example D201xxx there is no support for S3...
    to switch between standby S2-3 and hib S4, go to control panel > power options > advanced tab > choose one from "when i press the power button on my computer" combo box. if there is no hibernation option, check the hibernation tab if it is enabled (check if there is enough freespace on C: = size of ram). if there is no hibernation tab, check if all mobo and vga driver are installed...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Aug 2007
    Queens, NYC
    Quote Originally Posted by FPeter View Post
    S1 - on
    S5 - off
    Thanks. My MB bios has s1 and s3. For some reason, standby does not work. It keeps telling me that a device is preventing (hid, keyboard) the computer from standing by.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    You have to unselect the "allow usb to wake PC from standby" option in the bios and/or the device manager.
    Maximum Bitrate DeltaFX's Avatar
    France
    S0 is on
    S1 is cpu halted, cpu context/register/cache maintained
    S2 ...
    S3 is suspend to ram: cpu halted, cpu registers/contexts saved to ram
    and so on
    Now Galileo is real. Muhahahahaha :p
  1. laptop standby -> hibernate on battery doesn't work
    By dazman2 in forum How to Power a Laptop
    Last Post: 10-06-2008, 07:05 AM
  2. Hibernate automatically from standby?
    By jnorion in forum Operating System Optimization
    Last Post: 05-22-2007, 11:33 AM
  3. Problem: Standby, Hibernate, can only resume once
    By wuzzaap123 in forum General Hardware Discussion
    Last Post: 08-30-2006, 11:19 AM
  4. Standby or Hibernate w/ nlited windows
    By IntellaWorks in forum Power Supplies
    Last Post: 02-19-2005, 12:38 PM
