Results 1 to 3 of 3
Thread: Carpc components
    Mar 2008
    Carpc components
    Hi there. I have been slowly collecting a few parts for my carpc and just need some recommendations for my system.
    What I want to achieve-
    A fairly simple system with no internet access. In dash touchscreen for centrafuse (mostly for GPS and music) and a roof mounted composite screen only for dvd. I already have the roof mounted screen from the cars previous owner and most of the components for the system.
    I plan on getting an Intel D945GCLF
    Lilliput 629
    The things I am not sure on is the video and the sound.
    What can I use to send Video to the touch screen via VGA and to the roof screen via composite/vga? I want to be able to have centrafuse displaying GPS at the same time as the roof screen is playing a dvd. I have a radeon 9550 card with vga,composite and s-video, will this work?
    Now for sound. I already have a 4ch amp running my 4 speakers and a 2ch amp running my sub. Because there is only one PCI slot on the motherboard I will have to go for USB sound, or onboard sound?. Is there a card that will run front, rear and sub?
    Thanks for any input!
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    If you go for the d945gclf2, it has onboard vga and tv-out plus the onboard sound is 6 channel as opposed to the d945gclf2 which is only 4 channel onboard so you won;t need any add on cards at all It's only slightly more expensive than the d945gclf and it's dual core.
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2008
    That board looks perfect Nislo, had a quick look and i can pick one up for around AU$100. Just need to find out if it will support both its video outputs at the same time.
  1. What components to buy to make my CARPC
    By Charles1 in forum Newbie
    Last Post: 07-22-2006, 06:02 PM
  2. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  3. Replies: 33
    Last Post: 09-01-2005, 04:14 PM
  4. CarPC PictureViewer! works with ALL engine
    By dragonBTV in forum Software & Software Development
    Last Post: 02-02-2005, 08:56 PM
