Results 1 to 3 of 3
Thread: Disk Read Error with a good HD
    Nov 2004
    Albuquerque, NM
    So I finally got my glovebox system together (registered here and started collecting parts and info 4 years ago.) For info I'm using an Athlon XP mobile 2800+ in an Acorp 7KM400QP board with a WD800JB IDE hard drive. The mobo correctly identifies the hard drive (and IDE CD drive as well.)
    I formatted the drive and loaded WinXP, everything went fine until I was done installing. I reboot it and get 'Disk read error occurred Press Ctrl+Alt+Del to restart.' I have tried 2 IDE cables and I know the jumper settings are correct (tried incorrect settings and it hangs before the error message.) Thinking I had a bad hard drive, I pull it out and put it in my desktop. Surprise, it works fine - so I go through the rest of setup and install a couple programs. Put it back in the car, and still get the disk read error. I don't have a SATA drive to try...
    Any ideas on why I'm getting this error only when the drive is in the car PC? Bad IDE controller (why does the CD drive work, and why did WinXP install?) Something related to the M2-ATX not having enough power (runs the CD drive and HD while installing WinXP, but won't boot?) Anything?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    Is your car running when you boot the computer?
    Want to:
    Nov 2004
    Albuquerque, NM
    It gives me the same error whether the car is running or not, the electrical system has been tested recently and the alternator is putting out the specified 140 amps.
  1. Replies: 7
    Last Post: 07-19-2005, 06:24 PM
  2. HD not good
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 09-06-2004, 10:25 AM
  3. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  4. bad thing could turn good
    By bubbrubb in forum General Hardware Discussion
    Last Post: 07-15-2004, 09:06 PM
  5. Million $ Questiosn: HD screw size and wahz a good PC DVD player?
    By Tony S in forum General Hardware Discussion
    Last Post: 05-05-2001, 02:31 PM
