Results 1 to 3 of 3
Thread: USB->Serial adapter in Holux GPS receiver
    Jul 2007
    Norway
    I'm using a Holux M-215U GPS receiver. It is connected with USB, but the device manager reveals there's a usb->serial adapter inside.
    So, my problem.. It varies whether the GPS gets loaded after each restart or suspend. Every now and then (quite often if suspending) the COM-port does not appear in my device manager, and i'll have to unplug/replug it or restart.
    Any clues on how to solve this problem? I'm using windows now btw, but I had the exact same issue in linux.
    Is there a way to virtually unplug and replug it?
    If not, I was hoping somebody could recommend me a USB GPS device which actuall works - and copes with suspend! And maybe one with >1Hz update rate.
    Cheers!
    Elsewhere
    Is it plugged into a USB hub or directly to the motherboard?
    If it's plugged into a USB hub, try it connected to a port on the motherboard, using an extension if you need.
    How about the Wiki?
    Jul 2007
    Norway
    Quote Originally Posted by DarquePervert View Post
    No, it's plugged directly to the mb..
  1. FS: Holux GR-213 USB GPS Receiver SiRF III
    By elserpiente in forum Classified Archive
    Last Post: 01-23-2007, 09:23 PM
  2. FS: Brand New Holux GM-210 USB GPS Receivers
    By Hwonder in forum Classified Archive
    Last Post: 07-09-2006, 08:17 AM
  3. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
  4. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 03:54 PM
