Results 11 to 20 of 24
Thread: Lines going through the display
  1. #11
    Jun 2002
    Norway
    strange... hmm.. the ground point.. is it the same as the ground that the inverter / dc-dc psu has? ground EVERYTHING you could come up with... ... now you've only grounded your VGA card ? Right? .. well.... i dont think maybe bad grounding is your issue any longer.. hmmm
    sorry for not beeing any help
    Richard
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
  2. #12
    Dec 2002
    to this ground point, I have grounded the following
    1) amp (kenwood, for subs)
    2) psu
    3) motherboard
    4) inverter
    5) video card
    should I ground the hdd? just tap into one of the two black wire that goes to the HD...is that how you do it?
  3. #13
    Jun 2002
    Norway
    I found out today what was my problem.. The thing was, that the DVD-rom was monted elsewhere then all the other stuff.. this made the two components (dvd-rom and carputer) to have a different diffrencial .. (different ground) .. this picked up my noise... .. do you have any thing similiar ? a cd - dvd rom mounted anywhere :P .. ground the HDD ? .. if its mounted on the chassi, then that shouldnt be nessasry... dunno .. sorry
    Richard
    Albert Einstein
  4. #14
    Dec 2002
    now that you say it, i have my valentine 1 hardwired and grounded at the front of my car...
    thanks for the idea, i'll give it a try
  5. #15
    Jun 2002
    Norway
    there u go dude
    Albert Einstein
  6. #16
    Dec 2002
    uhhhh...didn't fix it :/
  7. #17
    Jun 2002
    Norway
    i forgot to ask, are these moving lines? .. "wobbling" lines or ?.. how would you describe them ?
    Richard
    Albert Einstein
  8. #18
    Dec 2002
    wobbling lines would be a good was to describe it i guess, like there is too much disturbance on the line
    I could cam the screen and show ya
  9. #19
    Jun 2002
    Norway
    have you tried to disconnect everything, and just leave the LCD in ? ... to see if that elliminates the problem?
    and just go from there....
    just a thought...
    ps: yeah.. take a picture lemme see...
    Albert Einstein
  10. #20
    Jun 2002
    Norway
    and, which kind of solution do you have? .. the one on the right ? or the one on the left? .. i'we seen cars that picks up disturbance if the video cable is on the same side as the 12V power cable...
    the red box beein' the carputer...
    Richard
    Albert Einstein
