Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Lines going through the display
    Dec 2002
    I finished my carputer No audio buzz...
    although, I do have lines going through the display (tm-701l) when I boot up the computer. The screen looks perfect when the computer isn't on (the blue, 'no signal' display)...I'm not really sure what it could be. I tired different video cable, but it produced the same effect. Any ideas?
    Dec 2002
    also what was that program that will strech my screen so it's not off centered?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Are they rolling lines? Like they move from top to bottom or bottom to top (I forget which)? If so I have the same problem. I'm guessing I need *better* sheilded video cable. Maybe.. any ideas?
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    and the answer to your second... TVTool
    Dec 2002
    well I thought TVTool was only for nvidia chipsets...i have an ATI 7500 AIW
    I tried monster (sheilded) cable...didn't help...and I guess you could say they are rolling from top to bottom, kinda hard to explain
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    TVTool is only for nvidia chipsets.. but I have an AIW that should be here tomorrow. I'll try it out and see what's possible but I don't know that anything is.
    I have the same problem you do with the rolling lines and haven't figured it out yet. The only thing I CAN think of is that the LCD is grounded to a diferent spot than all of the rest of the hardware. All of the rest is mounted in the back and run to a common ground. The LCD is grounded properly... just at the (obviously) front of the car.
    Dec 2002
    this is kinda weird...hasen't it happened to more people?
    Jun 2002
    Norway
    it happened to me ... had all kinda nasty lines .. and disturbance.. . dont know if the ground issue is your problem, but if so, i hope this could be some sort of a help .. (see picture below) .. ground VGA cards bracket to a good ground spot, a bolt or a screw in the chassi ... I did it... with the VGA, Motherboard, HDD, DVD-rom and PSU. .. before i did this, I had a problem with the sound, were the jack would have to be in a specific postion in the speaker jack on the soundcard, to not pick up any noise. Probably because it didnt get a good enough earth. This was the same with the VGA ... ..
    it all worked like a champ after I earthed everything up
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
    Dec 2002
    thanks tons i'll give it a try
    btw, you can adjust the moniter position through the tvout options...
    i didn't have the option before, but i unistalled the display / control center drivers...then reinstalled the newest ones
    Dec 2002
    didn't help much :/
