Results 1 to 5 of 5
Thread: EPIA M10000 (Nehemiah) Correct drivers and files
    May 2007
    Edit: installed latest drivers, everything going great now, use the drivers at viaarena.com
    Jun 2003
    Memphis - TN
    Ive heard if you lower the Hardware acceleration one notch in the display properties, it speeds up some of the videos/visulaizations.
    Try that.
    Im using the latest drivers.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    May 2002
    GA
    I am having the same issue.. cpu @ 100% when i start roadrunner. I have had this board for quite a while and just now starting to get back into trying to prep it for car use. I have been trying to figure this out myself.. I see a lot of people running this board and having no problems. I think it may be somewhat of a hardware issue.. I am only guessing here as i have very little background in motherboard arch. or electronics. I think that maybe some of these boards suffer from some defect. And I have one of them. I can say that one day about a month ago I was messing around with installing windows for the first time on the board, and i heard a loud pop come from the vicinity of the board. I had my head turned at the time but i know it had to come from the board. I pulled the power cord and checked it... nothing looked fried or felt hot, but i have noticed several capacitors that looked a little pushed out on the tops... Maybe this could be the culprit? I cannot speak for performance before this as I never hooked it up in the 3 years i owned it until that day.
    Could a capacitor cause such an issue?
    Just curious
    May 2007
    Update to the latest drivers and it should work fine.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Avogodro: Yea it looks like you have bad capacitors, especially if the tops are popped out. The old M10ks were effected by the bad capacitor problem, theres a long thread about it on the Via forums.
    As for the high resource useage playing mp3s, I have no idea. Right out of the box on my M10k, mp3s played just fine. WMAs are the ones that give me high cpu useage. Ive never found a fix to that, I just ended up converting all my wmas to mp3. Maybe try reinstalling the onboard sound drivers?
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 01:26 PM
  2. Camera Drivers missing in TinyXP, which files to add ?
    By Konrad in forum Software FAQs, Solutions, Tutorials
    Last Post: 01-19-2008, 02:42 PM
  3. StreetDeck and Via Epia M10000 Problems
    By carpcfreak in forum StreetDeck
    Last Post: 11-21-2006, 08:35 AM
  4. Integrating Epia MII drivers with nLite
    By Bailey in forum WinNT Based
    Last Post: 01-25-2005, 10:56 PM
