Results 11 to 20 of 26
Thread: Intel Desktop Board DG45FC Sound Quality
  1. #11
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Quote Originally Posted by bratnetwork View Post
    but i think my issue has something to do with my windows install bc the bios loads quick and the windows logo is decent but then it goes black for a bit after that b4 it goes into windows...
    Sounds like a driver is screwing around during load.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  2. #12
    Mar 2007
    Socal
    Quote Originally Posted by RedGTiVR6 View Post
    I also beg to differ that unless you're an audiophile you won't notice the difference. you don't have to have golden ears to hear the difference in audio quality. The only time I've seen that to be true is someone who has convinced themselves that they can't hear the difference because they can't or don't want to spend the money.
    I don't doubt that this is true on a good sound system, but I was referring to my desktop P45 board connected to normal computer speakers. I can definitely hear the difference between that and my other computer connected to a nice home system via sdpif.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  3. #13
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I was planning on just running the analog outputs into a set of JL Amps...
  4. #14
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    The bios does take some time to get it right.
    The boot isn't the quickest. Off al the boards out there, but mine is in the car, with full xp pro and all usb attached and using the m4 its up and running from hybernate after 23 sec after power on the m4 remote. And than its plays a song in RR.
    I use the alarm of the car to switch on the cpc, and it takes about 30 sec to walk to the car get in, buckle up (i have a volvo an the sound of not buckling up is not nice) and than turing the key. So there is 0 waiting time.
  5. #15
    Nov 2008
    how long does it take to boot up from just being off not in hibernation
  6. #16
    Feb 2007
    netherlands
    Quote Originally Posted by bmw_car_pc View Post
    i have to check that. I don't use min logon or somethin like that.
    Do you want it with a cold m4 or a hot m4 (hard off hasn't switched on yet) ?
    @ checked it: Cold m4 startuptime: 33 sec. (full xp no tweaks)
  7. #17
    Oct 2007
    Haledon, NJ
    I'll put it this way, in our car, we just walked away with 1st place Advanced Pro (by 30 points) & 1st place Pro Q & Best of Show at the 2008 USACi Finals.
    I'm running optic straight out of this board into our Alpine 701 for processing. I was running Centrafuse for this season for all audio.
    I've looked into the 701 and I really like it other than that you need the external controller for it, but I can get over that. The problem is that it doesn't seem to be readily available anymore - i guess they discontinued it...
    RedGTiVR6, do you think that if I ran the analog outputs into the Alpine PXE-H650 that I could get it tuned properly, or would the source quality just not be good enough?
    I would like to utilize the digital out of my board, but the selection of processors that support optical input seem to be scarce or just ridiculously expensive. I like the Zapco DSP6 bc it had PC control, but you have to use their amps and everything. Are there any other options that have digial sound processing with an optical input and RCA outs?
  8. #18
    Feb 2007
    netherlands
    Do i understand that that was with the dg45fc?
  9. #19
    Nov 2008
    Quote Originally Posted by rijk View Post
    if at all possible with a hot m4 i am just curious as the times in relation to my VIA EX15000g, thanks for your help
  10. #20
    _
    Mar 2004
    Little Elm, Texas
    Ebay is it really.
    The 650 really is going to limit you. If that's all you're going to use I'd say you would be limited. It's fine for a lot of things, but if the absolute best in sound quality is what you're looking for, then it's not going to give you what you want. Analog out of a computer to a car audio piece isn't the best option anyways.
    Processor Options
    Yes, with the DG45FC. Previously, it was done with an iBase iB899.
    Jan Bennett
  1. Quality of Intel MacMini audio
    By SigENeaT in forum MacCar
    Last Post: 01-11-2007, 04:12 PM
  2. RC3 Sound QUality
    By justintime in forum Centrafuse
    Last Post: 09-23-2006, 09:17 PM
  3. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 02:05 AM
  4. Quality of sound card.
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 04-21-2004, 09:18 AM
  5. sound quality of wafer 7850 ?
    By krazy in forum General Hardware Discussion
    Last Post: 07-08-2002, 05:48 AM
