Results 1 to 5 of 5
Thread: Carbuttons USB device...
    FLAC WuNgUn's Avatar
    Sep 2007
    Anyone have one of these? The website totally lacks any useful information.
    The device I got (Thanks Kalt!) has no markings on the PCB...
    The new model DOES have markings...I'm assuming the pinouts are the same?
    2 analog inputs with 2 grounds, 2 custom pins, IGN and voltage sense...
    I'm also assuming the pins next to AN2 and AN1 are the grounds?
    But what are the two trim pots used for??
    Sep 2007
    Also, when the device gets a signal, and it sends an output to the PC, how do you tell it what output to have? I know it's easy binding hot-keys in CF, but I gotta know what the device is outputing to configure that!
    Registered User
    Each trim pot adjusts the sensitivity of the analog input, that way you can have button separated by lower resistance. Those are ground pins next to the analog pins. Let me know if you have any more questions
    The link below has some more info on the device
    http://www.madhacker.org/usb_hid_keys.htm
    Sep 2007
    Thanks Kalt...
    I guess I can open Notepad when I want to config the outputs, see what each one does, huh?
    Registered User
    Quote Originally Posted by WuNgUn View Post
    Thanks Kalt...
    Yep, that's what i did.
  1. Replies: 412
    Last Post: 11-09-2011, 10:50 AM
  2. interesting way to install XP on cd-less/floppyless
    By gospeed.racer in forum Operating System Optimization
    Last Post: 11-11-2010, 07:55 AM
  3. lilliput won't work - USB device not recognized...
    By aegray in forum Input Devices
    Last Post: 06-16-2009, 03:38 PM
  4. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  5. Replies: 14
    Last Post: 08-15-2005, 07:27 PM
