Results 1 to 10 of 11
Thread: intel DG45FC
    Jul 2006
    new york
    intel DG45FC
    I wanted to buy this motherboard http://store.mp3car.com/product_p/mtb-060.htm
    and wanted advise as of which power supply to buy with it. i will run an intel core 2 Duo cpu E7300 and 4 gig memory. maybe vista for os and streetdeck.
    any suggestion will help
    Elsewhere
    1 - Use this as a guide for choosing a power supply: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
    2 - You don't need 4GB RAM
    3 - XP will provide much more compatability and support than Vista for vehicle applications, including Streetdeck.
    How about the Wiki?
    Feb 2007
    netherlands
    Quote Originally Posted by DarquePervert View Post
    US XP, get throw visto out of the window. 512 mb is enought. Ther is no diifernce in bootup time with 1 or 2 Gb. I use 2 Gb. But i also have no swapfile in Xp. This makes no differnces in boottime, but the cpc is a little quicker.
    For power, use a powercalculator. Usb uses a lot of 5 volt so look at that!
    i use the m4 and am happy with it. But not all the users have the same experience with it and like to get rid of it. (search on keyword m4) I use a lot of usb and the m4 has a lot of 5 volt.
    I have the cpc for 1 week in the car now and its al and more i hoped it would bee. I use a mtron ssd as os-disk and it boots up (cold m4 warm takes 2 sec less) 24 secs to boot (hybernate) into RR and play the song).
    The sound is great. Hits the lows also on the fronts. (i use DLS UP5 as ftont compo 60 HZ is as low as they get and the dg45fc makes full use of the whole frequentcy range.
    A lot of the onboards don't and even not all the external ones. But don't take my word for it, look at what Redgti has to say about the sound.
    Nov 2008
    i plan on using 4 gb in my new build just as it will allow room for in the future so i dont have to upgrade....
    i will have a similar new build also and was looking at a opus psu since they seem to have a better track record
    Jun 2008
    Camden / Australia
    you might need that 4g ram for your carputer in another 6 years, most of us are running under 2g quite happily and you will need 64bit vista to even support that much ram which we all know is still buggy as all hell
    Jul 2006
    new york
    i check the power table and notice the M2 PS will work also, the reason is that i have an ampie case and the M2 will fit perfectly. does anyone use this case with this setup? I'm concern with the heat and air flow if the case is too small....
    Jul 2006
    new york
    I got this http://store.mp3car.com/Mp3Car_DSATX_p/pwr-023.htm
    power supply and this case http://www.e-itx.com/morex-t3500b-pro.html
    hope it work well. I order it today. Did anyone use this case?
    Nov 2008
    Yeah 4GB is pointless, unless you need to run ton of softwares
    512MB-1GB is far enough for a carputer.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by ckegg View Post
    Agreed and unless you run a 64bit os you will be limited to actually using 3gig anyway as that is the addressing limit for most 32 bit operating systems... so it is a waste for no benefit.
    My first set up back in the dark ages was a p200 with 256k running win 95 and winamp.... car pcs just do not need that much horsepower.
    My current system does the same work (winamp) at less than 5% cpu load and darn small ram usage.
    TruckinMP3
    Read the FAQ!
    Jul 2006
    new york
    I agreed on the memory, I'll be running with only 2gig.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Replies: 26
    Last Post: 05-06-2009, 10:16 AM
  3. difference between 2 intel boards DQ45EK and Intel DG45FC
    By bmw_car_pc in forum General Hardware Discussion
    Last Post: 11-24-2008, 06:24 PM
  4. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 03:56 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
