Page 1 of 6 123456 LastLast
Results 1 to 10 of 56
Thread: Awesome new 3.5" board w/ C2D, DDR3, X4500, ALC888...
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    Just saw this one and thought people here may be interested:
    Form Factor
    3.5" Miniboard (146 x 101 mm)
    CPU
    Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB
    Memory
    1 x DDR3 SO DIMM support 800/1066 MHz up to 2.0 GB
    Chipset
    Intel® GM45 & ICH9M
    Real Time Clock
    Chipset integrated RTC with onboard lithium battery
    Watchdog Timer
    Generates a system reset internal timer for 1sec/min ~ 255 sec/min
    Power Management
    ACPI 2.0 compliant, supports power saving mode
    VGA Interface
    Intel® GM45 integrated GMA X4500 Technology
    LVDS Interface 24-bit dual channel LVDS interface Serial ATA Interface
    2 x Serial ATA II Interface with 300 MB/s transfer rate.
    Audio Interface
    Realtek ALC888 HD Audio LAN Interface
    2 x Intel® 82574L Gigabit Ethernet
    GPIO Interface
    Onboard programmable 8-bit digital I/O interface
    Extend Interface
    Min-PCI and PCI Express Mini card sockets
    External I/O Port
    2 x RJ45 LAN , 1 x SPDIF , 1 x PS/2 Keyboard / Mouse , 1 x VGA , 1 x COM
    Internal I/O Port 1 x RS232/422/485, 1 x SMBUS, 1 x IrDA , 4 x USB 2.0,
    1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD inverter
    connector, 1 x HDTV
    Power Requirement
    DC 12V input
    Board Dimension 146mm x 101mm (L x W) Operation Temperature
    0 ~ 60ºC (32 ~ 140ºF)
    Commell LS-373
    http://www.commell.com.tw/Product/SBC/LS-373.HTM
    Looks pretty sweet to me...may have to replace my LS-372...
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Nov 2008
    wow nice board now i have another option instead of the intel board
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i was just about to say not very car friendly with only optical toslink for audio but i just found this:
    http://www.amazon.com/3-5MM-TOSLINK-.../dp/B00006LVF3
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    i think more than 4 usb would be better than 2 x GIG lan ports
    guessing its been designed with server firewall solutions in mind
    Injector, that toslink to 3.5mm adapter cable.. its still an optical cable, just some plug types use the 3.5mm hole for optical in/out
    Mar 2005
    Rockledge, FL
    well that throws my idea out the window, but what about something like this?
    http://www.audiovisualonline.co.uk/v...r-plus-booster
    Jun 2008
    Seattle, WA
    Quote Originally Posted by Injector View Post
    It has a header on the board for audio, which I presume would give you all the normal analog input/outputs. It has a Realtek HD Audio ALC888 codec, which is quite good.
    Also, no one mentioned this:
    GPIO Interface
    Basically a built-in Fusion Brain! Albeit digital only, no analog. But still, very useful.
    This board looks very interesting.
    -- Kevin
    Dec 2002
    Hi galvitron, do you know of a compact DC-DC power supply board that has just a 4-wire 12V output?
    I've been looking for one for some time, and the best seems to be Liantec: ...but try finding one anywhere...
    All the DC-DC boards seem to have 20 or 24-pin...
    If you are going to spend the extra money on a compact 3.5" board it seems sensible to find equally compact peripherals...
    Mar 2007
    Socal
    The board has standard stereo headphone style jacks for stereo output via headers that go to a little mountable jack assembly about 2 inches wide.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    Nov 2008
    any idea on the price at all or when its available as i cant really find it much elsewhere
    Mar 2007
    Socal
    ^^ That unit actually looks good. I have something similar, the DSX12VD
    http://store.mp3car.com/DSX12VD_140W..._p/pwr-025.htm
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
  1. Gene 6320, 3.5" Board
    By sewy in forum General Hardware Discussion
    Last Post: 03-01-2005, 03:10 PM
