kino 9452 has a standard pci slot and runs core duo socket m processors. video is great.
better?![]()
My opinion is my own.
I don't run a case, but that also causes a problem when considering a PCI card...while a bracket can be made, I don't have the height available for it.
That might be another option for you to consider. At that point, air flow is much better. The down side is that you have to fabricate something to hold everything....which isn't that big of a deal for some.
Jan Bennett
Try this.
MSI Industrial GM45 Core 2 Duo Mobile Mini-ITX Mainboard
http://www.logicsupply.com/products/ms_9818
It has everything you want, great video capabilities, and can hold up to 4gb RAM (laptop RAM it looks like).
Next time you have specific requirements, you might want to list that requirement and not a brand name. As for a case, I would suggest a right hand riser and case for better airflow and heat control. The C137 is the only one I know personally, but it does have a place for an M2-ATX (handle most setups) unless you have more requirements that I am not aware of. I never suggested you switch to "OK" audio. I had no idea what a Lynx board was.
DanielKH - this one looks awesome)))))
I'm going to see if Travla C138 case would fit in my double DIn on top of the screen- that might be an ultimate solution for a form factor
As for the case, just keep in mind lots of stuff sticks out the back, so while it may appear to fit, you stick a serial plug or a big usb plug and suddenly, you're out of room. Also, when you put a lot of heat generating equipment in a small space (stacking them basically, also blocking airflow), you might be asking for heat trouble.
I do like that board. Seems really versatile too.
