Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: I am reading a lot about this D945GCLF2...
    May 2008
    One thing i have not read however is how much power it uses. Since the Atom330 processor is built in I looked it up on Chris Hare's page and it says power consumption is only 8W!
    Anyone have any specs on how much power this board uses? I am thinking maybe 20-30W total??? The reason I ask is I'm trying to decide on a power supply.
    Also, any input on how people have hooked this board up to a set of external amps would be appreciated. I am going to be using two amps, one for subs and one for a set of front comps. Both amps will be pretty good SQ and that's what I'm going for so I'm looking for a board that will give me that. Also, if the onboard sound on this board won't do it for good SQ, any recommendations on external sound cards (or PCI ones and a method to attach them securely in a bouncy car?)
    Also, one of the main things I will be using this PC for is mobile penetration testing so solid internet access is a must. I run my own pentesting company and will be using my car as a sales tool to show potential clients how easily their wireless networks could be attacked from the parking lot. I'll probably run either a dualboot system or XP w/ a VM version of Backtrack Linux. Will this mobo/processor/memory combo (if I get 2GB) handle such tasks?
    Thanks for any advice!!!
    Mar 2006
    Blog Entries
    1
    The processor alone consumes 8W, so yeah it'll be much more. Somewhere on the web I've seen wattage consumption comparisons (at idle, loaded down, etc).
    Apr 2008
    For me it was a big gain in reduced power consumption. Before I had a VIA EPIA board and I could not play any audio without running the engine. The sub would keep cutting out. Now with this cpu/board, I can run my audio with the engine off. I have not gone for more than ~20min, but haven't had a chance to find out what the time limit is. I'm using an M4 with 2 amps.
    May 2008
    Good info to have... I doubt I'd ever be running the PC w/ the engine off for any more than 20 min anyway. What are you using for a power supply? I was looking at the Opus 150W
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    mine is running with no acc stuff on, and i can leave it running for an hour now worries, had it running 2 hours and the car still starts.
    the battery i have is generic and nothing special.
    i just turn the screen off to reduce the attraction to the car, and push pause, hop back in after shopping and push play
    i have a 160W genius (m2 sort of thing) which has a low power shut down too.
    Oct 2008
    measured my board's power draw just now, during idle, it is drawing up 39W.
    Then ran Prime95, blend test (running both cpu at 100% and using up almost all the memory)
    it is drawing up 48W, that's with USB wifi on, and USB GPS on.
    Running the slim USB DVD drive adds about 7W.
    per the review here, http://www.neoseeker.com/Articles/Ha...om_330/15.html
    figures are about consistent.
    I have it plugged to a PSU test bench, I subtracted the draw from the PSU standalone while it is on, without the PC plugged in. PSU is plugged to Killawatt meter.
    May 2008
    Alright thanks for the info. I rounded up and estimated 50W for the mobo. I figure with 2 gigs of ram and the mobo at full draw w/ a hard drive/cd drive/all basic hardware stuff running a 160-180W PSU will be plenty
    220W will be overkill but I may spring for that just for the ability to upgrade in the future if I want.
    Edit: and yea haha I read that same review, that's why I rounded up and made it 50
    Oct 2007
    Auckland
    inverter?
    just get a car rated dc-dc PSU
    Newbie VYSSO3's Avatar
    Dec 2008
    Melbourne Australia
    Hey guys,
    I just purchased this board, the D945GCLF2, with integrated Atom 330.
    Before doing so, i read a tonne of reviews, including the one posted by f1ip, and although results varied from review to review (probably die to varying hardware attached via USB and what-not), I found the following -
    * CPU - 8W nominal
    * Intel NB - 20-30 W (varies accross reviews but this is the apparent letdown on the mini-ITX boards ATM
    * ICH7 SB - 5-7W with 2 SATA and 1 IDE Device.
    I have mine hooked up on a test bench with an M2-ATX (which doesnt even get warm) - running:
    * 2GB Kingston DDRII
    * Wireless USB Mouse / KB
    * Netgear WG111v2
    * Globsat BU-353 GPS Mouse
    * 120 GB WD 2.5" SATA HD
    * MinTV USB DTV Stick
    * Panasonic slot load USB DVD RW
    Note that i DID have to buy the m2-ATX p4 harness seperately, and that although the board has a 24 pin ATX style connector, the older 20 pin job works fine.
    Quick system, have extensively tested Hibernation and sleep, run it over night, loaded the CPU, definately no issues with hibernation or stability on Win XP Sp3 integrated.. The NB fan is a little on the noisy side, but nothing to be too worried about. I did notice an option to tweak this fan in BIOS - yet to play with it.. Ill wait until the VOOM2 arrives and i can do some temp testing before i do this.
    Cant say much for onboard sound, i only have a 3.5" to RCA going to my home rig ATM, which sounds OK. Waiting for the SPDIF header plug to come, and of course, ill report back on the onboard sound quality when the whole lot is in the car. I'm expecting a bit of noise as usual from the onboard sound chips.
    Id also like to extend a warm thank you to all you guys who have posted on this forum before. Im new here but you have all helped me with my choices and planning immensly. Thank you!
    Cheers,
    George
    May 2008
    Edited...been at work too long, I didn't mean inverter lol.
    BTW, any input on the other questions in this thread? Will this setup be enough to run virtualization software (VirtualBox, not VMWare) or would I need to do a dual boot? And how bout the audio? Anyone hooked this mobo up to an external set of SQ amps and have feedback (forum feedback, not speaker feedback) :P?
  1. Replies: 26
    Last Post: 05-06-2009, 10:16 AM
  2. Thanks a lot..
    By ToddBt in forum Newbie
    Last Post: 03-07-2007, 05:49 PM
  3. Replies: 27
    Last Post: 09-02-2006, 12:39 AM
  4. Outside Temperature reading
    By Civic03 in forum Software & Software Development
    Last Post: 08-07-2006, 09:30 AM
