Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: hdd endurance
    Nov 2008
    hdd endurance
    I'm installing a laptop and was wondering...will the hdd survive the bumpy roads and the "moving" environment??
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Laptop hard drives are a lot more durable that desktop drives. If you search around these forums you will find mixed experiences of the durability of hard drives. Ive read some people that say they go through drives constantly and some that go 4x4ing all the time and never have an issue. For the most part if you have decent laptop HD and you give it some sort of anti-vibration mounting it should last for a while unless you like to hit pot holes often.
    If your really concerned about it then I would recommend investing in a Solid State Drive. They are quite pricey but very effective.
    If you don't want to spend that money just back up your setting and use you laptop as is and if it does die you can then decide what to do and you'll have it all saved
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    another option are rudgized hard drives. Western Digital and a number of other manufactures make them for the military.
    Personally, I've been running desktop hard drives for years with a vertical mount. The only time I've had an issue is when a dropped a drive when taking it out of the car.
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    Nov 2008
    i'm planning to put an acer aspire, 3680 i think...
    it's a decent, mid budget laptop...
    i'll see, if it disappoints me, i will replace it with a eee pc...
    tnx for the reply
    edit:
    is the hdd position standarded, how shoul i turn it?(hdd vertical mount)
    Oct 2007
    Haledon, NJ
    Again there is much debate over the vertical vs horizontal mounting... the theory behind mounting it vertically is that when you hit a bump there is less chance of the head hitting the surface of the disk. There is about 0.003" between the head and surface and if the head hits the surface its ruined. I have my mounted vertically just because thats how it fitted where I wanted it.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Hard drive orientation in the car environment
    Also, covered in the FAQs (seventh item under "Car PC General"): http://www.mp3car.com/vbulletin/advfaq.php
    Want to:
    Oct 2007
    Haledon, NJ
    Since the hard drive is mounted inside the laptop and there isnt much that you can do to change that other than use an external drive, i would recommend that you mount the entire laptop with some sort of vibration or shock resistant mounting. Look around the forums for ideas of how to this. Everything has been done from suspending items in rubber bands / chords, to using an anti-vibration mounts that are used on for automotive ignition boxes in racing applications.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by bratnetwork View Post
    I would not endorse this method. It can introduce more motion than a firm fixed mounting method.
    Your cars suspension will be just fine. Do not let the hardware bounce inside the car.
    TruckinMP3
    Read the FAQ!
    Oct 2007
    Haledon, NJ
    I use the anti-vibration mounts from an MSD ignition box. They are still a nice sturdy mount that doesn't allow things to bounce around. Basically its just a piece of rubber with a stud coming out of both ends. It hold things in place but just absorbs some of the vibrations that the car experiences. Won't do much for pot holes or bumps in the road.
    http://www.jegs.com/i/MSD/121/8823/10002/-1
    I personally don't like the rubber band method either, I was just examples of what some other members have implemented.
    Nov 2008
    i'm thinking of making some kind of "walls" made of wood and a piece of spunge at the bottom...putting the laptop verticaly but with plenty of room besides the laptop and the walls
  1. Hard Drive Issues in a Vehicle Computer
    By DarquePervert in forum The FAQ Emporium
    Last Post: 02-23-2008, 02:35 PM
  2. HELP - resume issue - HDD broken?
    By quinrod in forum General Hardware Discussion
    Last Post: 01-28-2007, 09:40 AM
  3. HDD gone bad?
    By VanMan69 in forum General Hardware Discussion
    Last Post: 08-07-2004, 06:55 AM
