Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 50
Thread: Cold weather lock up problems
  1. #11
    Oct 2006
    laptop hard drives are fluid bearing, but desktop hd are not. Hence they're better in the cold. SSD although said to have operating temp of 0*C, i wouldn't be surprised to see them working well below -30*C.
  2. #12
    Dec 2008
    i have an issue with this too. plus, sometimes my touch screen will turn blue, then gradually turn every pixel white. strange.
  3. #13
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Wrong. Lots of desktop HDDs are fluid bearing as well.
    EDIT: Quick example http://www.newegg.com/Product/Produc...82E16822144102
    Tidder
    Try RevFE
  4. #14
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    If you have access to a somewhat heated garage, maybe just try a simple test of parking the car as it is setup currently in a garage lets say at 45-55 degrees F for a few hours and then boot it up and see if the problem goes away... cheap and easy test before you go spending money and find its not what you thought...
  5. #15
    Oct 2006
    You're right, i guess they're a lot of fluid bearing right now. Must be for the quieter performance.
    But all my car's hard drive has been wheel bearing drives (old used ones). They work great for the cold, but only last about 1 winter, then i just swap it out for another. I believe there are still plenty of wheel bearing HD around. So have a look at ur local computer store.
  6. #16
    Newbie theforce's Avatar
    Jan 2007
    Ohio
    Well I removed all my USB devices today and the computer still locked up except this time it locked up on the XP logo screen. The temperature last night was the coldest since the computer started locking up to this might explain the quicker lock up this time.
    Quote Originally Posted by BlackStealth View Post
    Keep in mind most SSD drives don't recommend operating below 0C.
    Yes but a lot electronic equipment has an operating range of 0-70 yet they still operate below freezing. Like my old MP3 player and my cell phone. I would trust an SSD to run at or below freezing.
    Quote Originally Posted by nobb View Post
    I thought that the main reason hard drives dont work in the cold is because they fail to spin up fast enough as the fluid bearings become viscous. Usually if the drive manages to successfully spin up and boot, then the system has no problems after that.
    I thought that too and that is whats throwing me off is that my computer will boot all the way to the desktop. Well except for this last time.
    You can check if it is your drive by taking it indoors and leave your system out in the cold. Then while the drive is still warm, quickly connect it and see if you get any problems.
    I guess this is the next logical step. I was not wanting to take the computer apart because its a little bit of a pain.
  7. #17
    Mar 2006
    Blog Entries
    1
    If you're gonna buy an SSD drive just buy the version that operates below 0C. You don't want to make the mistake of purchasing equipment twice.
  8. #18
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Punky View Post
    laptop hard drives are fluid bearing, but desktop hd are not. SNIP
    This is not accurate. Some drives are offered only in FDB others offer both and some only with out FDB.
    TruckinMP3
    Read the FAQ!
  9. #19
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by TruckinMP3 View Post
    We already covered it Truckin.
    Tidder
    Try RevFE
  10. #20
    Jun 2002
    Colorado
    Quote Originally Posted by Tidder View Post
    Thanks, read the rest of the thread after I posted that.
    TruckinMP3
    Read the FAQ!
  1. M10000 mobo in cold weather (-40C)? Any problems?
    By nobb in forum General Hardware Discussion
    Last Post: 02-19-2008, 07:55 PM
  2. How do i setup Weather?
    By liquid_smoke in forum RR FAQ
    Last Post: 09-17-2006, 03:32 AM
  3. OPUS 90watt not powering up in Cold weather - solved
    By The Grinch in forum Power Supplies
    Last Post: 02-21-2005, 12:48 PM
  4. Cold weather and computers
    By Weatherboy in forum General Hardware Discussion
    Last Post: 02-12-2005, 12:07 AM
  5. Cold weather hurt it at all??
    By Cue in forum General MP3Car Discussion
    Last Post: 01-10-2001, 11:40 AM
