Results 1 to 10 of 13
Thread: Diagnostic help please
    Sep 2007
    West Springfield, MA
    First off, I'm almost a complete newb when it comes to computer repair. I feel like I've learned a lot from this project, but am still not confident enough buy the parts I think are bad. Anyway, here's my case.
    Two days ago, got in the car and the PC wouldn't start. No post, nothing. All I was getting was the speaker pop of what I think is it starting to turn on, then an immediate pop after that. After the second pop, I could tell the PC was off because I do get some ground noise only when the computer is off. This was a constant cycle until I turned off power to the IGN line on my M2. My first thought was that the M2 was bad, causing it to "hold" the button making the computer turn on and off like this. I brought the computer in the house to figure it out exactly, hooked it up to an AC ATX PSU, using my TV as a monitor (though it's VGA port) and a spare mouse and keyboard to fiddle around if I got it running. First time, It did POST normally. I was pretty happy. But it couldn't seem to find a bootable drive. I noticed that the Molex plug for the HDD wasn't plugged in all the way so I shorted the Mobo pins that would attach to a case switch again to turn it off. I made sure the HDD was plugged in this time and tried to start it up again. This time, both the case fan and CPU fan turn on for less than a second and stop. I get no POST or anything else. I hooked it up to speakers and get no sounds. The funny thing is that it will only do this once at a time unless I cut the power from the PSU and start fresh. Now this leads me to think the Mobo is bad. I really have no better conclusion because I'm pretty new to this. I would appreciate any input/advice that anyone may have. I would like to be as certain as possible when buy replacement parts because I am on a budget. The hardware that I'm using is in my "CarPC" specs in my profile if that helps at all.
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    Before buying anything, unplug it, then disconnect or remove the BIOS battery, wait a minute or so, then reinstall, hook up the power and restart.
    My opinion is my own.
    Sep 2007
    Ok, gave that a try. It made the fans spin for quite some time, but that seems to be the only difference. Still no post or anything.
    Sep 2007
    Beaverton, Oregon
    Disconnect the harddrive and anything else that might be connected (dvd, usb stuff), pull the RAM and reseat and restart. See if you get a POST.
    Sep 2007
    Still no Post. And still doesn't turn on more than once without cycling the power from the PSU.
    Sep 2007
    Beaverton, Oregon
    My guess would be the RAM, but it could be the mobo too. Hard to troubleshoot those without a second computer that uses the same RAM or CPU.
    Sep 2007
    Well, it's got an intergrated CPU, so I couldn't switch that out if I wanted to. It's kinda funny how I've been thinking about upgrading the mobo/RAM for some time now. Right now it's the intel D201GLY with 512MB of Ram. I really like the new board with the Atom processor. So maybe I'll order that after the holidays along with a 1GB Ram stick.
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by blackcobra487 View Post
    It would probably be cheaper if you were already looking at a new board.
    Sep 2007
    Something else sparked my mind, warranty. I've only had the board for 6 or 7 months. But I bought it as a complete Carpc from Mo-co-so, so I don't have a receipt for the board itself. Makes me think I can't go this route.
    I've actually been pricing the new intel board with the Atom processor. NewEgg has it for $70 and 1GB RAM sticks for $10. So either way, it isn't a huge hit in the wallet.
    Sep 2007
    Ok, an update.
    I just got the system to successfully boot! I don't know what's different, but it's running fine. Although during the Intel splash screen I hit F7 to get into the bios but it went straight to startup. Also, it seems this only works once every few tries.
  1. 2001 Nissan Hardbody 3.0i V6 diagnostic connector
    By peetgrobler in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-25-2008, 09:03 AM
  2. FS: OBDII diagnostic interface
    By deskcom in forum Classified Archive
    Last Post: 12-10-2004, 12:24 AM
  3. Anybody using OBD-II diagnostic stuff??
    By mp3commander in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-01-2004, 03:16 PM
