Results 1 to 10 of 12
Thread: Adding battery to system
    Dec 2007
    anyone every add a battery, i know you can relocate it to the trunk pretty easy but what about adding a second battery in the trunk
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Sure, but what do you think the benefit will be?
    TruckinMP3
    Read the FAQ!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The FAQ Emporium has an article on adding a battery, called a 'tank circuit'.
    You have to include circuitry to prevent one battery from draining the other one.
    Want to:
    Dec 2007
    Quote Originally Posted by TruckinMP3 View Post
    a battery to run my electronics on, my bat to start my car keeps draining if i dont drive it for a few weeks and since this is my fun vehicle i dont want to come out to a dead battery when i want to drive it.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you drive it infrequently, you don't need a second battery. You need to have the PC shutdown completely or hibernate when you turn the car off.
    The max you are going to be able to sleep your computer without draining a secondary battery is going to be a week or perhaps a little longer.
    Shutdown will shut the computer OFF and stop any drain at all.
    Want to:
    Mar 2008
    I had to go to a second battery with the older vehicle(95 GMC van) that I have. I could never over come the PC shutting down and restart of the vehicle and yes I had a smart DC-DC (M2-ATX)power supply.
    Go to your nearest Stereo shop and have them setup battery backup like they would for Stereo and hook that up to the PC.
    Dec 2007
    Quote Originally Posted by Bugbyte View Post
    I did, i installed a cut off switch, i used the 12v yellow ign wire from the stereo harness and installed a switch so i could turn it on and off.
    Jul 2002
    If I leave my Toyota Taco for too long without driving it, the battery will be discharged just from the stock equipment like the keyless entry that is on all the time. It will be more than a week before that happens, but not months like an old vehicle I have that has no continuous small loads on the battery.
    Tank circuit seems to be a mp3car-ism I've not seen used anywhere else for a dual battery setup. A tank circuit to most people is an inductor-capacitor resonant circuit. See http://en.wikipedia.org/wiki/LC_circuit. A better thing to do is search for battery isolators. There must be at least a couple dozen different brands from heavy-duty solenoids with a controller to electronic switches. Lots of off-road people use dual batteries to provide extra power for winching or as a backup. Some use the second battery to run accessories like lights and refrigerators overnight and don't want to discharge their main starting battery. If I had my way, I'd redesign the electrical system so only the starter and engine contol module was on one battery and everything else including the stock equipment like lights and radio was on another battery, but thats a pretty involved project.
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    I got a 2nd in the trunk.
    this is my isolator
    http://www.grainger.com/Grainger/items/6C028
    and i use 2 relays, one that turns the solenoid on with ign on and one that shuts if off when the starter starts(dont want it blowing fuses and what not).
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Dec 2008
    why not make it easy and just use a battery isolator?
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Replies: 17
    Last Post: 09-30-2009, 07:03 PM
  3. Good read on ground loops
    By coffeejolts in forum Car Audio
    Last Post: 04-28-2008, 01:30 PM
  4. Replies: 1
    Last Post: 06-27-2005, 08:16 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
