Results 1 to 6 of 6
Thread: Nano or Pico ITX @ 2ghz+?
    Oct 2008
    Good Afternoon!
    I've done a fair amount of searching, and I can't seem to find what I am looking for.
    Are there any nano or pico itx motherboards that are 2ghz or higher? I plan on using the mini itx dg945fc, but the form factor of a nano itx/pico itx is a bit better. I would like to use the double din bybyte chassis/case for the PC and screen.
    Oct 2003
    Copenhagen, Denmark
    Quote Originally Posted by Archy88 View Post
    Good Afternoon!
    I believe the fastest of the via boards is the SN series or something, up to 1.8Ghz, but if you wan't fast in a small package, look at 3.5" SBCs instead from ex. Commell or Portwell. The LV-372/371 is quite a powerhouse for it's size.
    http://www.via.com.tw/en/products/ma...erboard_id=550
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    Oct 2008
    Alright, you threw me for a loop there. Back to noob HQ, what is a 3.5" SBC? I see you are using one of the LV series. Are there any rough/laggy areas for the setup? Or does it perform pretty much flawless.
    All google results pull up embeded solutions. I'm assuming its another word for tiny form factor(ex. pico) that can be "embeded" for other uses?
    Oct 2003
    Copenhagen, Denmark
    sbc is just another word for single board computer, which is commonly used for the smaller embedded motherboards available from vendors like Commell, 3.5" is just a form factor like nano-itx, which is the same size as a regular harddisk 3.5inches. My setup is actually the ls-372 now, with a T7500 core 2 duo cpu and 2 gig of memory, with a CF card to boot from, and there is absolutely no laggy areas on that platform, it is however quite expensive. Take a look here : http://www.commell.com.tw/Product/SB...ed%20miniboard
    and prices for some are here : http://www.bvm-store.com/ProductCate...ubCategoryId=2
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    2GHz 2GHz - but what kind of 2GHz? this freq with a VIA C3/C7 or transmeta CPU is nearly equal to nothing... an old northwood celeron / P4 at 2GHz is a bit slow too, but a core solo / duo / core2 or any newer AMD Athlon beats the previous CPUs at 1200-1500MHz... so, only the freq means nothing...
    there are several different intel and amd CPU based mobo in nano/pico ITX form, for example comell boards, but the ITX size is much cheaper in most case
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Oct 2008
    Touche FPeter...
    I guess I would have to say Core 2 is what I am looking at. It simply seemed that most of the boards I was interested in, were around 2ghz. Therefore, it was a pretty easy base to make a post about. But I was wrong...lol.
    I'm looking to run videos or music w/ gps and no slow down. I was also like the ability of using it as an HTPC(That's certainly secondary...for those cold harsh weeks where my mustang is undriveable). Overkill is never a bad thing if I wanna dabble with more advanced uses.
    The 371-374 boards seem pretty sick.
    The reason I'm thinking of pico/nano is the fact that I could use a case similar to this:
    http://bybyte.com/nano2din0308.htm It'd be awesome to have an all in one solution that is slightly difficult with a mini-itx board.
    Bybyte does have a mini-itx/LCD chasis, but it's an inch deeper than the pico/nano one. If I can fit the mini-itx I certainly will. A bit of measuring is coming up on my next day off.
    http://bybyte.com/2din0308.htm
  1. Fanless 1GHz Pico ITX Car PC with Xenarc x7000
    By gltovar in forum Show off your project
    Last Post: 03-09-2009, 09:09 PM
  2. nano itx motherboard
    By millsy in forum General Hardware Discussion
    Last Post: 08-11-2008, 11:11 PM
  3. Nano ITX and Windows XP ???
    By jwh02017 in forum WinNT Based
    Last Post: 11-04-2006, 05:49 PM
  4. Nano ITX in an Evo
    By SAScooby in forum Worklogs
    Last Post: 12-06-2005, 04:54 AM
  5. NANO ITX boards are finally at the mp3car store!
    By god_of_cpu in forum General Hardware Discussion
    Last Post: 09-12-2005, 01:35 PM
