Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: px10000g audio connector
  1. #11
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Can you post detailed pictures of connectors?
  2. #12
    Nov 2008
    Las Vegas
    1) workstation
    2) built-in/default windows sounds. (the "HDAUdIO deck" EQ shows activity when using mediaplayer)
    3) 2.5" - 3.5" ata drive adapter. pins removed and soldered directly to it. and soldered to 1/8" jack. wire is 28awg. continuity has been tested w/ a multimeter from end to end with no problems and no shorts.
    I'll see if I can get some good shots for you when I wake up tomorrow.
  3. #13
    Aug 2008
    Guam
    Quote Originally Posted by Pseich0 View Post
    1) workstation
    1) Are you using headphones? I recommend cheap ones because they'll be powered directly from the motherboard
    2) Try an mp3
    3)Okay, I really need to see this connection. How are you doing this....?
  4. #14
    Nov 2008
    Las Vegas
    It looks like the audio was in fact dead. I managed to find myself another board tonight and got it working right away. For the sake of those that might need this later, and those of you who tried helping me out thus far here's a pic of what did work.
    1 (black) = Right channel line out (pin 5)
    2 (red) = Left channel line out (pin 7)
    3 (black) = A_GND (pin 2)
    you can't see the connection to ground because i stripped it a bit long and it goes to the back side but it's the first pin back there.
    @ratbagu I was using a powered set of logitech speakers. your advice on using un-powered headphones was good though, would probably filter out some noise from amplification at least.
    I'm not sure why trying an MP3 would have made a difference. Especially if I don't even have a decoder installed yet, since I'm using XP with almost everything stripped out of it. A wav is raw sound and almost universal in the sense that any audio player has the ability to play it. Of course a 2 sec "click" from the default sounds isn't a huge help in debugging some output issues.
    ^ just my 2 cents
    I'm just glad I finally have sound from something
    Now i'm off to wiring up power for the LCD
  5. #15
    Aug 2008
    Guam
    I mentioned it only because I was testing my install with a wav sound and it wasn't working. Turned out that I stripped my xp so much that last sound file left was actually a 'blank 1kb' file-no sound in it. I kept playing it waiting for sound but nothing ever happened. I threw in an mp3 and it played just fine.
    I work as an enterprise-level network administrator, so if I ask stupid questions, it's because I've experienced, or my people have done even stupid-er things..
  1. Newbi Question on Audio
    By hpprose in forum Car Audio
    Last Post: 09-04-2007, 03:19 PM
  2. Audio Muted on startup
    By liquid_smoke in forum Road Runner
    Last Post: 08-12-2006, 02:31 AM
  3. FS: Carputer Parts
    By Shamingo in forum Classified Archive
    Last Post: 06-16-2006, 06:27 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. some audio questions for my setup
    By PatrickB in forum General MP3Car Discussion
    Last Post: 05-11-2005, 08:37 AM
