Results 1 to 10 of 15
Thread: px10000g audio connector
    Nov 2008
    Las Vegas
    Has anybody managed to custom-make an audio hookup for the EPIA pico-itx px10000g board? The board I got didn't come with one and I've been unable to find one for sale anywhere. I've been attempting to break-out based on the manual from there website but for some reason I can't get it working.
    So far I've only tried stereo but since it's a surround codec I might be missing something (sense, LFE/Center/surr, etc).
    If anybody can at least point me in the right direction I would be very grateful, as this is really really REALLY starting to bug me.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Yes Im do it cca. 1 year ago on my old px board... You can see it on my thread(Fiat Stilo by _Dejan_)...
    Nov 2008
    Las Vegas
    I've read through your post on that project before and never caught anything.
    Just to be sure I read through it again and saw what you posted at the end. I'm gonna try changing it up in the software as well as using the mic input (although that seems a bit odd to me).
    btw, I went through multiple ways of connecting to the jumpers and finally ended up going the same route using the IDE adapter
    Nov 2008
    Las Vegas
    Just tried using line out, mic in, line in. changing through 2, 4, and 6 channel.... nothing.
    I know i have some sort of connection, as I'm getting a buzz and some popping as the system boots up on a pair of "decent" speakers. I also get some feedback when I change the volume...
    I'm thinking it's somewhat possible I shorted something along the way and fried the whole chip or it just came doa
    Oh well, guess I'll go USB...
    Aug 2008
    Guam
    I'm pretty sure the pico-itx boards use a 2.0mm pitch terminal connector. You can buy some from digi-key.com. I bought 25 of the plastic connectors )http://search.digikey.com/scripts/Dk...&name=H2011-ND) and 25 of the crimp terminals. It'll work with some 28 AWG wire.
    You can also wirewrap the terminals and solder the wires straight to an audio connector. I bought a 3.5 mm audio jack connector and the breakout board from Sparkfun: (http://www.sparkfun.com/commerce/pro...oducts_id=8032) You can probably get the connector cheaper through digi-key but I bought it through Sparkfun because of the breakout board. I knew 100% it would be compatible.
    Aug 2008
    Guam
    Quote Originally Posted by ratbagu View Post
    I'm pretty...be compatible.
    Oh, I may misread what you were trying to say.
    Just make sure you have the connectors up right.. what kind of sound are you getting out of it?
    Nov 2008
    Las Vegas
    right now nothing but static along with some "popping" during bootup as everything initializes.
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Can you post which PIN's do you use for IN, OUT, MIC? When Im have it(One year ago) Im connect it without problems and test MIC and OUT...
    PIN Pitch is same as have 2.5" HDD so smaller then normal ATX boards. Im make connector from 2.5" to 3.5" IDE adapter...
    If I remember you must use A_GND pin and not GND for ground...
    Nov 2008
    Las Vegas
    I tried using both A_GND and GND.
    from the manual, pin 1 = Line In R, 2 = A_GND
    2
    1
    5 = Line Out R
    6 = Mic R
    7 = Line Out L
    8 = Mic L
    Aug 2008
    Guam
    Quote Originally Posted by Pseich0 View Post
    2
    1
    5 = Line Out R
    6 = Mic R
    7 = Line Out L
    8 = Mic L
    I have a few questions then to help solve this problem:
    1) Are you testing this on a workbench and not in your car?
    2) What sound/music file are you using to test the sound?
    3) How are they connected? (solder/wire-wrap/terminal connector)
  1. Newbi Question on Audio
    By hpprose in forum Car Audio
    Last Post: 09-04-2007, 03:19 PM
  2. Audio Muted on startup
    By liquid_smoke in forum Road Runner
    Last Post: 08-12-2006, 02:31 AM
  3. FS: Carputer Parts
    By Shamingo in forum Classified Archive
    Last Post: 06-16-2006, 06:27 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. some audio questions for my setup
    By PatrickB in forum General MP3Car Discussion
    Last Post: 05-11-2005, 08:37 AM
