Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Voltmeter for computer
  1. #11
    Jun 2008
    Camden / Australia
    looks like left pins require a 5v source for power and the right goes to the battery you want to measure did you get any documentation with it?
    1993 Mitsubishi Verada
    My Ride
  2. #12
    Aug 2007
    nope none, thats why I got it for like 12 bucks shipped. What is a 5v source and should I be alright just using 18 gauge wire to measure the battery?
  3. #13
    Sep 2005
    Looks like you just need a 5v regulator or just use the power from a USB port (just get the polarity right first!!). oh, and yeah you can use any gauge wire to measure volts as it only requires a small amount of current to read the voltage.
    Normally automotive type volt meters don't require a separate supply to measure voltage, so it looks like this unit can measure all the way down to 0 volts (providing that 5v is active all the time).
  4. #14
    Variable Bitrate vincenttor's Avatar
    Nov 2008
    wow thanks for all the reactions,
    yeah the separate volt meter i have thougt of that
    but its nicer if its integrated ofcourse in the computer
    im using centrafuse and got a elm327 scanner also
    i will try with some other programs to see if i can get the voltage on my computer screen
    thanks for the response everybody
  1. Looking For USB Voltmeter or simliar device
    By mukow in forum General Hardware Discussion
    Last Post: 09-17-2009, 12:49 PM
  2. Voltmeter Placement Thought? I want your opinion
    By Anshu in forum General MP3Car Discussion
    Last Post: 03-24-2006, 10:27 PM
  3. Replies: 22
    Last Post: 03-04-2006, 09:35 PM
  4. digital voltmeter = interference??
    By owibitmytongue in forum General Hardware Discussion
    Last Post: 09-01-2004, 08:26 PM
  5. looking for a small voltmeter
    By aoLhaTer in forum LCD/Display
    Last Post: 08-19-2004, 02:50 AM
