Results 1 to 10 of 11
Thread: [SOLVED] New Intel D945GCLF2 Board Not Booting
    Aug 2008
    I recently purchased this board and I'm currently using a regular power supply / case to move forward with the OS / software installation. Unfortunately the board will not boot.
    Originally, when I turned on the power supply, the green LED on the board would light up and I would have to press the power button on the case to turn it on. When I pressed the power button though, the CPU fan would spin for about a second and then turn off. No output was displayed to the monitor.
    As I've been troubleshooting, one thing I tried was removing the battery, unplugging all power from the board and letting it sit. Now, when I turn on the power supply.. the CPU fan spins... shuts off, spins again, and then shuts off for good.. the power button does nothing. I can kill the power to the board, and repeat this process.
    So far I have disconnected everything except the essentials. Even tried replacing and removing the RAM to see if I could get the RAM boot error, but nothing at all. I do know the power supply is good. The power supply I'm using is an Antec 24 pin 450W ATX power supply and I am providing the 4-pin P4 power as well.
    Anybody have any ideas or suggestions?
    Aug 2008
    For good measure I went ahead and put the system I was using back together and online (yes it works without any problems) and used another PSU and case in a last attempt before asking for an RMA. This PSU works without any issues. I have no idea why it wouldn't boot with the other one... but at least I get to POST now.
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    I had a similar problem with a psu's 24 pin connector to the mobo. I used a 20-24 pin adapter and it stopped my problem.
    Feb 2007
    I recently started work on my board, had a problem, couldnt load xp, would get to the first restart then bluescreen or lock up one way or another,tried two ide leads i had and two 3.5 and one 2.5 hdd,all the same thing, ready to throw it in the bin and as last resort tried the ide lead that came with the board,hello xp loaded up without a problem,on close inspection i found this, what i thought was a break and trashed the lead,i have no idea why it is there,why it wouldnt work with a lead without the "break"i notice also both leads i have had Foxconn c, 0333 printed yet one came with the board and one i have had for many years, the leads without the "break" dont have the foxcomm printing on them, hopefully some sazy tech can shed some light on this "coincidence"
    Aug 2007
    Quote Originally Posted by jrbush82 View Post
    This is weird because my board sorta booted up (I had all those time/date errors) but then my power supply started smoking up. I thought it was because if was to strong for these boards (thermaltake 400 W) I guess im wrong. I am using the 20 pin connector from my thermaltake power supply from my main computer and I also put in the 4 pin power supply (also from thermal take) onto the board? Any Ideas?
    Variable Bitrate Deric's Avatar
    Sep 2006
    Quote Originally Posted by TexasAggie View Post
    I placed mine in an old case with a 350W power supply and had no issues.
    Aug 2007
    Quote Originally Posted by Deric View Post
    That is how mine looked, well with memory in it. Why would the power supply be smoking any ideas?
    Aug 2008
    There is a risk when using a 20-pin power supply instead of a 24-pin power supply on a 24-pin motherboard. That risk is heating due to more power being drawn from the 20-pins than what it was designed for (as I understand it). I would recommend moving up to a 24-pin PSU if your are having heating issues.
    Sep 2006
    Do you have it in a case or sitting out on something? Is it possible something shorted out against the bottom of the motherboard and went back to the PSU?
    Aug 2007
    hmmm well it was sitting on the side part on my old case so that could be it. Ill have my m2-atx coming in here shortly so maybe itll be fine once thats going.
  1. Intel D201GLY BIOS Petition, Mobo selection (C2D?) and test results!
    By Lope in forum General Hardware Discussion
    Last Post: 09-02-2008, 07:55 PM
  2. New Intel Mini board
    By Woofnstuff in forum General Hardware Discussion
    Last Post: 04-03-2008, 09:12 AM
  3. Intel D201GLY2 low profile fan upgrade success! [pics]
    By maniaxzero in forum General Hardware Discussion
    Last Post: 02-16-2008, 10:12 AM
  4. Intel D201GLY2 Issues - Bad Board?
    By PhatMo in forum General Hardware Discussion
    Last Post: 01-10-2008, 02:52 PM
  5. New Intel "Shelton" mini-ITX board
    By kronos in forum General Hardware Discussion
    Last Post: 05-16-2005, 01:35 PM
Tags for this Thread
