Results 1 to 4 of 4
Thread: How many fusion brains are possible?
    Jan 2008
    Dartmouth, MA
    I have not experimented with fusion brain yet, but I wanted to know if there is some limit to the number you can use. Some time within the next few years, I plan to make a beastly car pc which controls EVERYTHING, yes everything (even remote driving for the hell of it). For this it seems I would need to use many fusion brain boards, is it possible to use an unlimited number of fusion brain boards?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by PaulF View Post
    You are limited by USB alone. 127 devices - 1 for the root hub, and -1 for each hub are allowed to be connected to each root device.
    Also keep in mind the more devices you have connected the more the USB bus is being used. So the maximum update speed is reduced.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    Dartmouth, MA
    Alright, thanks.
    About how much bandwidth does each fusion brain need/want?
    Mar 2006
    Bandwith is shared around 250 kbps. So 250Hz max. Add 1 more brain at max communication settings, and the new max is 125Hz. But what you do is you put all the time sensitive data on 1 Brain, and have that update fast with the other things like temperature update less. The temperature now and 1ms from now dont feel any different so it can go on a slow update brain.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  2. Replies: 68
    Last Post: 04-23-2009, 12:38 PM
  3. Replies: 3
    Last Post: 09-23-2008, 09:00 PM
  4. **NEW Fusion Control Centre Configuration Wizard!**
    By 2k1Toaster in forum FB Software
    Last Post: 09-08-2008, 12:51 PM
  5. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 08:42 AM
