Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: where can I find low profile sound card?
    Apr 2000
    Little Rock, Arkansas
    Ive looked throughout the web and can't seem to find a low profile sound card. Im not particularly happy with my onboard sound and want to get a decent sound card but Im using a book-size pc. Ive found a low profile 3D vga card w/ TV out, I would think I could find a low profile sound card. Anyway, help would be appreciated.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    Sep 2002
    Just North of Toronto, Ontario, Canada
    i dont know about low profile sound cards, but you should try looking around for usb sound cards. theres a bit of info about them on here, i dont know if theyre any good or not, but it shouldnt be too hard to find out.
    Project AutoBoxen: Coming along, almost ready to hook up in the car.
    Celeron 500, 192mb ram, 8gb hdd, other stuff.
    '91 Mazda 626: Its free, so ill use it.
    Variable Bitrate Ashlawn Kemling's Avatar
    Feb 2001
    Williamsport, PA
    Look on http://www.compgeeks.com
    Bought an Aureal card on there. It's somewhat low profile, but the connectors stick up maybe a bit too far.
    May 2006
    Low Profile Sound Card
    Finding reliable and worth while devices for slim line cases is a pain.
    Here is a low profile 7.1 Surround Sound card that comes with the short or low profile brackets for those cases.
    Cobra AW870LP Low Profile PCI Sound Card 7.1 Surround
    [AW870LP]
    Hope that helps with your search.
    Elsewhere
    You do realize that this thread lay dormant for over three years before you resurrected it, don't you?
    How about the Wiki?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    well for future searches. i have a echo gina3g soundcard that has a low profile pci card and break out box. 5.75 vrms on the outputs too.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    that's awesome....and it's his first post too!
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    hey scott - I may have asked you this already, but I've slept since then...lol
    those connections on the gina would require modifying some RCAs to make them work, right?
    go from a 1/4" jack to a regular style RCA....right?
    Jan Bennett
    Dec 2004
    Los Angeles Ca
    yup. I'm actually making my own cables too. I need to go 1/4 TRS to the proprietary zapco connections. then the zapco connections to xlr. and using all Neutrik connectors (pro sound studio connectors)
    to make a balanced 1/4 TRS to rca, you just need to ground the neg phase signal wire to the shield (closer to the rca connector) I wish i could let you know how the card ultimately sounds...but i have probably about two weekends left before i can fire it up
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Newbie MCE_BEGINNER?'s Avatar
    May 2006
    essex, england
    hey people found a low profile sound card that is good the " prodigy 7 lt
