Results 1 to 9 of 9
Thread: What is this cable! And where do I get one?
    Oct 2005
    Coventry, RI
    Its the cable that connects from the hardrive to the mother board but its a custom cable and I cannot find another one to save my life! For once google has failed me
    Anyone know where I can get one of these? As you can see this one got hacked to high hell when I was removing the drive by accident.
    Cable has this on it: Cableplus E96118
    MOBO is: EPIA-SP
    95 AWD Turbo Talon 2.4L :D
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    How about this
    Google for "40 to 44 pin cable".
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Oct 2005
    Coventry, RI
    Nice but none of them look like my cable. They have different connectors than mine.
    Jan 2008
    These are standard cables for laptop hard drives, the one listed above is exactly the same as yours it just looks different in the picture.
    Oct 2005
    Coventry, RI
    Quote Originally Posted by coreyspeed View Post
    It looks the same but the connector is different. How do I find the one with my connector. What is it called?
    Low Bitrate vtecfelon23's Avatar
    Dec 2007
    Baltimore
    http://store.mp3car.com/IDE_to_Mini_..._p/adt-007.htm
    It looks like your just has a floppy connector on it.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    what are you trying to plug into that cable a laptop hard drive?
    Jun 2004
    Rochester
    Not a "floppy" connector
    Quote Originally Posted by vtecfelon23 View Post
    Floppy drives use 34 pins, IDE uses 40. Mini IDE uses 44. It is definetly not a floppy connector.
    @chowda633: coreyspeed is right, that is the cable you want - 40 to 44 pin IDE. Here is another example:
    http://cgi.ebay.com/2-5-TO-3-5-HDD-H...3A1%7C294%3A50
    Good Luck.
    ** Denotes an "in car" post
    In-Car posts made from passenger seat - Be safe, Don't Post and Drive.
    Dec 2008
    I think the plug he is referring to being different is the white 2 pin plug on the end of the red wire.
    Here's what you can do though:
    use the 40 to 44 pin ribbon cable listed above that has the 4 pin molex then use this 4 pin mole to 3 pin header adapter
  1. Sharp 4LU4E Ribbon cable - Where can you get one?
    By pigseye in forum LCD/Display
    Last Post: 09-23-2008, 01:33 PM
  2. Where to purchase touchscreen cable?
    By SuperMatty in forum LCD/Display
    Last Post: 06-12-2003, 08:18 PM
  3. Where can I get 80 pin IDE cable?
    By jtk in forum General Hardware Discussion
    Last Post: 01-27-2003, 03:29 AM
  4. Where to buy LCD backlight cable?
    Last Post: 08-07-2002, 04:19 PM
  5. Replies: 4
    Last Post: 04-10-2001, 01:10 AM
